While driving home from work in what had been my flawless, 63,000 mile, '05, 6.0 powered Superduty, a chime went off, the towhaul light started flashing, and the message center was telling me to check transmission temp. When I looked at the transmission temperature gauge, it was on the peg COLD!
After I got home, in a panic I called the dealership. I was told they couldn't get me in for several days and it would cost 150.00 diagnostics at which point they would go no further until I was talked to.
Welp, over the weekend I did a search (thanks Al Gore) and found the following (and many similar) post on a message board;
This was followed by this:
I contacted Vince and he was kind enough to supply me with the appropriate pictures and yesterday I ordered the sensor, a case of Mercon SP, and a filter. Last night I drained and pulled the pan changed out the sensor and put her all back together. After driving it to and from work today, everything worked perfect and I've declared it fixed.
My 05 trans gauge will be working then just lay over on cold then my message board will come on to check trans temp and my tow/haul light blinks.
It sounds like you have a bad temperature sensor.
Once you remove the pan locate the sensor in the valve body and remove the electrical connector very carefully. The sensor is about the size of a pen cap. To remove the sensor carefully unlock the stop tab and twist it, pull down to remove it. It comes out before a full quarter turn is made. Put it back in the reverse order. When you get the sensor to come out be prepared to catch the trans fluid that follows behind it, you will get less than a quart out of it.
Background info:
The transmission fluid temperature (TFT) sensor twist-locks into the solenoid body. The TFT is a temperature-sensitive device called a thermistor. As the transmission fluid temperature rises, the TFT resistance decreases. The powertrain control module (PCM) monitors the voltage across the TFT sensor to determine transmission fluid temperature. The PCM uses the TFT signal as an input to determine cold and hot temperature shift and TCC scheduling.
BTW - the temp gauge is a glorified "idiot" light as its response is severly dampened. Between 100-220F the needle will remain in the same position on the gauge. At 230F it will move up slightly to the middle of the normal range. At 250F it will move to Yellow, seal damage occurs at 250F after moderate exposure time. At 280F the gauge will move to Red.
