Go Back   Ford Truck Fanatics > Special Interest > Motorcycle/ATV
  #11
Old 04-01-2016, 08:36 PM
fatherdoug's Avatar
Thank you, Duncan. I also noticed that aluminum on the inside of the side panel next to the exhaust. I might try that, I'm going to extend the wires running to the winch. The local supply store had 8 gauge red but no black, so I ordered some. Should be here on Monday.
I also changed the oil in both units. I didn't realize that the oil would shoot out of there like a, well, I'd better not say............ Anyway, it missed the pan. Also added oil to the front hubs/gear case.
'78 F-150 Lariat
Quote:
Quote:
  #12
Old 04-01-2016, 08:38 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Lol...and...regarding that 8 gauge...is it flexible, as in many fine strands?
What kind of crimper are you going to use?
Quote:
Quote:
Quote:
  #13
Old 04-01-2016, 08:51 PM
fatherdoug's Avatar
The original wire that came with the winch is 8 gauge fine strand, but what I bought today is coarse(less strands with thicker wire. I'll be using the crimper that I have. School me!
'78 F-150 Lariat
  #14
Old 04-01-2016, 08:53 PM
DNFXDLI's Avatar
Admin
The less strand wire is not as desirable in a location where vibration is present...just a heads up.
Can you post a pic of your crimper?
I've found the best stuff to use is welding cable.
  #15
Old 04-01-2016, 08:56 PM
fatherdoug's Avatar
I have a cheap ass crimper from wally world. I'd be to embarrassed to show it. It crimps the connector all the way across, rather than putting a square hole in the middle, if that makes any sense.
'78 F-150 Lariat
  #16
Old 04-01-2016, 09:02 PM
DNFXDLI's Avatar
Admin
It does....and no need to be embarrassed...the issue is that those tools will not make a reliable crimp especially on that kind of cable.
For the use I would assume that you would be using...you might want to consider one of these:
http://www.amazon.com/ProDeals%C2%AE...s=wire+crimper
  #17
Old 04-01-2016, 09:09 PM
DNFXDLI's Avatar
Admin
And...I would strongly suggest that you use heat shrink with sealant...if you don't have any, I can mail you what you need to save you buying a 4' piece.
  #18
Old 04-01-2016, 09:15 PM
fatherdoug's Avatar
I hope I can pick up both of those items tomorrow. Thank you very much for the help.
'78 F-150 Lariat
  #19
Old 04-01-2016, 09:17 PM
DNFXDLI's Avatar
Admin
Tech support line will be open if needed
  #20
Old 04-01-2016, 10:42 PM
fatherdoug's Avatar
Thank you. I'm stuck with what comes out of the solenoid, and the sad part, is that is 5' of wire, unless I make my own solenoid.....
'78 F-150 Lariat
