Go Back   Ford Truck Fanatics > Special Interest > Motorcycle/ATV
  #11
Old 03-22-2016, 12:41 PM
fatherdoug's Avatar
After farting around with a pair of needle nose pliers for about 3 hours, I finally broke down and called one of the auto mechanics that works at the power plant and borrowed a pair of CV clamp pliers. I told him what I wanted, and he said "How long have you been trying that with needle nose pliers"?
Took about 45 minutes to get everything back together, AND it works. It was a learning experience!
Thank you all for your help!
'78 F-150 Lariat
Quote:
Quote:
  #12
Old 03-22-2016, 02:03 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Glad you got it! I've done it without the proper tool before but you pretty well need two guys for it to work. Or four hands, anyway
-Frank
Quote:
What's your view on sheep?
  #13
Old 03-22-2016, 02:11 PM
fatherdoug's Avatar
After snooping around the underside of the 4wheeler, I discovered the right rear outer boot was also torn. It is making a clicking noise, so I'm assuming the CV joint will need some work. This was NOT the blue one. Just wanted to clarify that.
'78 F-150 Lariat
  #14
Old 03-22-2016, 02:31 PM
SuperCab's Avatar
Super Moderator
Super Moderator
Well you're a pro at it now... The rear one should be easy
Glad it was your green one... I'd feel bad if the blue one suddenly started having problems!
-Frank
  #15
Old 03-22-2016, 05:06 PM
fatherdoug's Avatar
It wasn't as daunting as it looked, plus a phone call from the hotline.
'78 F-150 Lariat
  #16
Old 03-22-2016, 06:40 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Wait until the invoice arrives
Quote:
Quote:
Quote:
  #17
Old 03-22-2016, 06:54 PM
fatherdoug's Avatar
Do you take Rupees? Got the back one off this afternoon. I have to make an 80 mile trip in the morning to pick up a new boot. The joint itself looks to be in good shape.
'78 F-150 Lariat
  #18
Old 03-22-2016, 06:59 PM
DNFXDLI's Avatar
Admin
Good that the joint looks in good shape...but didn't you say it was clicking?
  #19
Old 03-22-2016, 07:31 PM
fatherdoug's Avatar
Yes, it is. I should just bite the big one and replace the CV joint?
'78 F-150 Lariat
  #20
Old 03-22-2016, 07:33 PM
SuperCab's Avatar
Super Moderator
Super Moderator
Usually if they're clicking they're on their way out
-Frank
