Go Back   Ford Truck Fanatics > Engines > 7.3/6.9 IDI
  #21
Old 12-21-2014, 05:54 AM
flareside_thunder flareside_thunder is offline
flareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond reputeflareside_thunder has a reputation beyond repute
Yup. You can do the 2 cycle in place of the fuel treatment. Should quiet her down some too.
  #22
Old 01-01-2015, 12:02 AM
clutch's Avatar
clutch clutch is offline
clutch will become famous soon enoughclutch will become famous soon enough
holy old thread batman! Wanted to update, ended up needing a new starter this past spring, and a couple more fuel lines got replaced this fall.
"...went back to the old Ford V-8. Can't beat that engine for getting there, oil-burner or no."
William Burroughs, Naked Lunch
Click for Truckee, California Forecast
  #23
Old 01-01-2015, 12:18 AM
Fellro's Avatar
Fellro Fellro is offline
Admin
Those starters can sneak up on you. I had one that got progressively slower, but I hadn't really noticed until it nearly wouldn't start. Changed it out, and what a difference...
My trucks:
