Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #1
Old 10-11-2016, 09:27 PM
fatherdoug's Avatar
Rotten eggs in water tank?
I winterized our fifth wheel last week and in the process of pouring antifreeze into the water tank, I got a really strong H2S smell(rotten eggs) coming out of the fill spout for the water tank. After dumping the antifreeze into the tank and recirculating the antifreeze through the faucets, I got the same smell when I opened the faucets to the bathtub. The water tank had been completely drained after the last use, and so were the gray and black water tanks.
I had never had this problem with my previous camper. Any thoughts? Would a weak solution of bleach solve this problem?
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 10-11-2016, 10:25 PM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
asked the rents since they use to have a camper if they ever had the problem.. stated they never did.. but wanted to know if you were using RV antifreeze or car antifreeze as they are different... im assuming your using RV but wasnt 100% sure... they said if your going to try flushing it with bleach to write the mfg of what you were using first incase there could be any adverse reactions.. or flush the system real well (they suggested 3 or 4 times) before trying with the bleach... then do the same again before loading it up with the antifreeze again...
they did state theirs had a smell to it but wasnt a rotten egg smell.. so they werent sure what could have caused it... writing the mfg could get some clues there too.. they may know what could have reacted to it...
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #3
Old 10-11-2016, 10:31 PM
fatherdoug's Avatar
Thanks for the info, Shawn. Yes, I use RV antifreeze.
'78 F-150 Lariat
  #4
Old 10-11-2016, 10:33 PM
Sparky83's Avatar
no problem... hope you get it figured out...
Shawn
-John F. Kennedy
-Christopher Titus
  #5
Old 10-12-2016, 03:24 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
I've heard people talk about a sulfur smell in well water and something about a bacteria (sulfate bacteria maybe?) that causes it. Not sure how to treat it but treating a tank and a very small water system sounds much easier than trying to get the bacteria out of a well (assuming that's the cause). Maybe call an RV dealer and run the bleach idea past them(?).
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #6
Old 10-12-2016, 06:28 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
You have bacteria in the holding tank.
Add bleach and fill the holding tank and run all the taps till you can smell chlorine and close the taps and let it sit a few hours and flush the system.
Some people add a little vinegar to the holding tanks it keeps the tanks fresh smelling and changes the pH of the water to retard bacteria growth.
Click for weather forecast
________________
Randy
  #7
Old 10-12-2016, 07:24 AM
fatherdoug's Avatar
Thank you, both. I will try that. The term is SRB(Sulfate Reducing Bacteria) which is an anaerobic bacteria. It thrives in oxygen deficient environments. Apparently the tank on this camper does not drain completely when you open the drain.
WE need a gross bacteria smilie.
'78 F-150 Lariat
  #8
Old 10-12-2016, 12:01 PM
Quote:
....an anaerobic bacteria. It thrives in oxygen deficient environments......
The type of bacteria found in every properly functioning septic tank, how nice!
Hey you, after my request from a few weeks ago for the waffle with the circle and slash (ie, no waffling) is done!!!!
-Bill
  #9
Old 10-12-2016, 06:01 PM
smokey's Avatar
hitech hillbilly
Admin
Glad to be of assistance on the holding tank.
I will add some of the smilies soon. Just been swapped with work. After 12 hours repairing computers a day I just haven't got around to putting upntje smiles.
________________
Randy
  #10
Old 11-14-2016, 06:18 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
One other thing it could be as well is the water heater anode. They typically need to be replaced once a year.
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
