Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #11
Old 06-04-2016, 11:22 PM
fatherdoug's Avatar
Quote:
Originally Posted by DNFXDLI View Post
Cool Doug, probably the easiest thing to do.
I might be using the red phone.
'78 F-150 Lariat
Quote:
Quote:
  #12
Old 06-06-2016, 12:12 PM
fatherdoug's Avatar
Got the new power converter installed and it's up and running. Everything works now, either in AC mode or DC mode. When I pulled the old converter out of the cabinet, about half of the ground wires to the lights, fans, etc, had been pulled out of a wire nut and were laying loose. Hence, not all lights worked. It looks like the converter had been replaced once before by somebody that knew even less about electricity than I do.
Kudos to Progressive Dynamics! The instructions were VERY well written( not translated) with pictures to show location of pins, plugs, etc.
After the wiring mess was solved, installation only took about an hour for a nonelectrician.
'78 F-150 Lariat
  #13
Old 06-11-2016, 08:16 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Right on Doug!
Quote:
Quote:
Quote:
  #14
Old 06-11-2016, 09:54 PM
fatherdoug's Avatar
Thank you. You would have had an aneurysm after seeing the wiring.
'78 F-150 Lariat
  #15
Old 06-11-2016, 10:43 PM
DNFXDLI's Avatar
Admin
I'm now limited to one a day...so probably best I didn't....
  #16
Old 06-11-2016, 10:55 PM
fatherdoug's Avatar
'78 F-150 Lariat
