Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #371
Old 06-17-2018, 12:36 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Quote:
Originally Posted by dustybumpers View Post
Just a silly question, but....
How come you don't have a small plasma cutter?
Perfect excuse to buy one right there....
You know, I don't know why we didn't use the plasma cutter.....hmmm.
Quote:
Quote:
Quote:
  #372
Old 06-17-2018, 07:19 PM
fatherdoug's Avatar
Quote:
Originally Posted by DNFXDLI View Post
I was gonna use processed beer....
Do they still make Schlitz?
'78 F-150 Lariat
Quote:
Quote:
  #373
Old 06-17-2018, 07:20 PM
fatherdoug's Avatar
I see why they put handles on the batteries.
'78 F-150 Lariat
  #374
Old 06-18-2018, 02:46 PM
dustybumpers's Avatar
He'll just grind them off....
Charlie
  #375
Old 06-23-2018, 08:48 PM
DNFXDLI's Avatar
Admin
Bahahahaha!!!!!
Not this time
  #376
Old 06-23-2018, 08:54 PM
DNFXDLI's Avatar
Admin
Thought I had a match to the engine hatch paddle latch....not so once I investigated more.
Latch is just worn out and pivot points more bend than move the way they should.
I decided to see if I could rework it....a couple of threaded inserts, some drilling and some stainless nuts and bolts seem to have worked...I did use red (permanent) locktite on them.
Bellcranks got adjusted as well, but some may need to be removed and cut down as they are maxxed out on adjustment....in any case, it seems to be working better.
  #377
Old 06-23-2018, 09:01 PM
DNFXDLI's Avatar
Admin
Also started on mocking up the 12 volt distribution.
Making cables/lugs for the switch was going to be a PITA so I picked up some 1-1/4 x 1/4 bus bar.
Did the bending with a vice and a 3 lb deadblow
The outline on the bench is the size of the steel plate I will mount everything to.
Bus bars will be coated in liquid tin and then rubber self vulcanizing tape to insulate them.
Initial layout and size that got changed:
On with the bending:
Final layout....increased the height of the panel to 14 inches.
  #378
Old 06-24-2018, 08:47 PM
Could you powder coat them?
Charlie
  #379
Old 06-24-2018, 10:51 PM
DNFXDLI's Avatar
Admin
I could, but I want some good insulation on them. After more thought I think I will use some thick wall heat shrink.
  #380
Old 06-25-2018, 03:07 PM
Ya. I think that will look better than tape. Plus, you know over time, the glue un gummy's and comes apart making a gooey mess
Charlie
