Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #1
Old 06-30-2014, 10:04 PM
fatherdoug's Avatar
Replacing electric brakes with new
I'm ordering new electric brakes for the 18' travel trailer. One of the wheel bearings grenaded last summer, and got hot enough to destroy the functioning parts of the brake, so I'm going to replace all 4 of them(2 axles).
I plan on soldering the new brake wiring to the old wiring and sealing with heat-shrink tubing. Is there anything else I need to do to ensure a watertight seal?
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 06-30-2014, 10:25 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
I've never seen one not work... I've done some pretty bad brake wiring
I think if you take the normal precautions you shouldn't have any issues.
-Frank
Quote:
What's your view on sheep?
  #3
Old 06-30-2014, 10:29 PM
fatherdoug's Avatar
Thank you, Matt. The electromagnet came out in pieces on the brake that got hot.
'78 F-150 Lariat
  #4
Old 06-30-2014, 10:47 PM
SuperCab's Avatar
Super Moderator
Super Moderator
It won't work that way?
-Frank
  #5
Old 06-30-2014, 10:53 PM
fatherdoug's Avatar
Doh!, No!!!!!
'78 F-150 Lariat
  #6
Old 07-01-2014, 02:54 AM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
See if you can find the heat shrink with the glue inside of it
Mark
  #7
Old 07-01-2014, 05:30 AM
Fellro's Avatar
Fellro Fellro is offline
Admin
Sounds like you will do a fine job Doug, they really don't require much. Put a bit of grease on the pivot too.
My trucks:
  #8
Old 07-01-2014, 06:13 AM
fatherdoug's Avatar
Quote:
Quote:
Thank you, both. I will find the "improved" heat shrink. I've also heard that antiseize works well on the pivot?
I'm also replacing the bearings and drums.
'78 F-150 Lariat
  #9
Old 07-01-2014, 06:34 AM
Fellro's Avatar
Admin
That should work fine. The ones on my sister's horse trailer actually seized up in service.
My trucks:
  #10
Old 07-01-2014, 08:17 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
What Mark said about the heat shrink with sealant...also, use metal butt splices and crimp them before soldering....if you can't find the plain metal ones, use a pair of side cutters and remove the insulation from an insulated one.
Quote:
Quote:
Quote:
