Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #1
Old 01-04-2014, 07:18 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
utility bed and a goose neck
What's the statistics on that working out in my favor? Or is it a better bet to go with a flatbed and do tool storage under?
Пробковыйy
  #2
Old 01-04-2014, 07:27 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Check out the pics of the 92. We have a hidden ball in it in the flat bed and it has side boxes. Just have to watch the angles on turns some times. I also have the hitch closer to centered above the axle, but it is a dually. My sister runs a horse trailer, I have run my horse trailer converted to a two car hauler on it.
My trucks:
  #3
Old 01-04-2014, 07:58 PM
1970Custom's Avatar
They call me Spuds
This is probably the way I'll go....
http://www.cbtrailers.com/truckbeds-steel.htm
Пробковыйy
  #4
Old 01-04-2014, 08:13 PM
Fellro's Avatar
Admin
It depends on how exactly you want to use it. The higher side boxes have their benefits, but definitely can get in the way if you want to be able to access from over the side. I definitely suggest you make it totally surrounded so that things don't slide off. Tie downs are something you definitely will want.
My trucks:
  #5
Old 01-04-2014, 08:14 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
I'd prefer no trailer...they wind up being a PITA.
Quote:
Quote:
Quote:
  #6
Old 01-04-2014, 08:16 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
I've seen low utility boxes with gooseneck trailers. Be slick if you could put together a truck/trailer combo that worked. I love utility boxes.
Or as duncers said, get a truck that does everything you need and 86 the trailer if possible. They are a bastard.
-Frank
Quote:
What's your view on sheep?
  #7
Old 01-04-2014, 08:18 PM
Fellro's Avatar
Admin
Once again, depends what you want to do... I just can't quite get one let alone 2 cars on the back of my truck... tractors don't fit very well either.
My trucks:
  #8
Old 01-04-2014, 08:22 PM
SuperCab's Avatar
Super Moderator
Super Moderator
Trailers are a must have, I just hope he's not planning on using it everyday. That's what I was trying to say.
-Frank
  #9
Old 01-04-2014, 08:24 PM
Fellro's Avatar
Admin
We have it available, but definitely not a daily use. Being that is how we have always used ours, I figured it was more of an option than a daily use.
My trucks:
  #10
Old 01-04-2014, 08:54 PM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
Just throwing an idea out there Eric - What about an E350 diesel box truck for your mobile workshop ...... a tail lift and some cutouts along the sides where you could put access doors to get at your tools without going through the back.
That would give you a good gvwr and tool storage as well as the towing ability if needed.
Maybe something like this http://modesto.craigslist.org/cto/4256546413.html
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
