Go Back   Ford Truck Fanatics > Engines > 351M, 400
  #11
Old 11-19-2014, 09:00 AM
LEB Ben's Avatar
LEB Ben LEB Ben is offline
LEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond reputeLEB Ben has a reputation beyond repute
Quote:
Originally Posted by Treims831 View Post
So I got the engine build which is now a 400m. I cannot get the 78 f100 to idle properly. The fuel pressure is good, there is a new carb on it (edelbrock 600). It will idle high as then it will want to die. When I get it idling not too bad it pretty much stalls when I put it in gear and it misfires. Seems to smooth out when RPMs are up as it has lots of power it's just the idle. It also doesn't want to idle at all on factory timing setting, I have the timing as high as possible without pinging so that it will run. Any ideas?
Timing should be around 12*. Stalling once in gear is usually a vacuum issue...unless you have a choke issue, which could also explain the back fire. What are your idle speeds set at??? On a warm engine, I like 650rpm in drive at idle. These numbers will obviously change depending on build, but give a starting point.
'77 250 400 Boggers (show)__'96 350 CC 460 SSR's (work)__'79 Bronco 400 35's (play)
Quote:
Inspired by Ian
We live in a society that keeps finding answers to problems people never knew they had.
I bow my head to Jesus, stand for my family, love only one woman, and am always proud of what I have.
Standing by my gun and Bible since 1986.
Ben
  #12
Old 11-19-2014, 12:38 PM
Treims831 Treims831 is offline
Treims831 is on a distinguished road
I can't find a vacuum leak anywhere. I've sprayed all over with wd 40 but no luck. I've tried different choke adjustments. It idles at just over 1000. Any lower and it stalls out. I replaced intake gaskets trying to fix a possible vacuum leak.
  #13
Old 11-19-2014, 09:13 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Definitely sounds like a vacuum leak
-Frank
Quote:
What's your view on sheep?
  #14
Old 11-20-2014, 07:38 AM
LEB Ben's Avatar
1000 is too high at warm idle. I usually prefer starting fluid over wd40. Typical vacuum leak areas: intake manifold (I like using a valley pan with a crush seal just for this reason). Also, did you use the front and rear seals??? Those typically don't set well and spit out. Next would be booster and the check valve. After that, a half dozen or so lines that run the HVAC controls, trans modulator, reservoir, etc. However, with the exception of the intake, the other would have accompanying issues.
Have you got a timing light on this thing yet??? I've had similar symptoms when the timing chain jumps a tooth or two. It'll still run (like crap), but you get back fires and a lot of the symptoms you're describing.
Quote:
Inspired by Ian
Ben
  #15
Old 11-28-2014, 12:18 PM
I have a timing light and have been trying different timing degrees. I checked the timing chain and it was right on the mark. I just used silicone for the front and rear seals, otherwise I had oil leaks. I am going to try plugging off all vacuum lines at once an see what happens.
  #16
Old 11-28-2014, 04:19 PM
fatherdoug's Avatar
Do you have access to a vacuum gauge. What the needle does on the gauge will eliminate some possibilities. The way the needle behaves could indicate a problem, based on the directions that come with the gauge. I haven't used mine for a few years, so I don't remember the indications.
'78 F-150 Lariat
Quote:
Quote:
  #17
Old 11-28-2014, 04:29 PM
Big Jim F150's Avatar
Big Jim F150 Big Jim F150 is offline
73-79 Ford Trucks Rock
Big Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the rough
You might try blocking off one vacuum line at time, and see if you can find the offending line, and it'll save you lots of confusion when trying to locate your problem. You might also want to check your vacuum advance on your distributor, the little chamber that's on the front or side of the distributor, and you might want to check the little vacuum line going to it. Did you have your distributor rebuilt when you rebuilt your engine? You might have a bad pickup wheel on your distributor, you might also want to check all your electrical connections as well, for you might have a bad or loose connection somewhere, or possibly a pinched wire somewhere. Hope you find this helpful to you .
Big Jim F150
1978 Ford F-150 Ranger Lariat
  #18
Old 11-28-2014, 08:13 PM
Distributer is rebuilt. I have a vacuum gauge in the cab and it bounces from 14hg to 16
