Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #11
Old 08-06-2013, 08:54 PM
nobodyspecial's Avatar
nobodyspecial nobodyspecial is offline
Fire in the hole...
nobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond reputenobodyspecial has a reputation beyond repute
Here is the hitch I stole off of my Dads new camper. It is too narrow, and the bolt holes don't line up. As you can see, just to move it, I put the back two bolts in, and let leverage hold the front against the camper frame.
Here is the original:
I don't want to put a 5th wheel mount in a truck (that I don't even have yet) because I use the bed too often. I hideaway gooseneck ball is the way I will go, as our other trailers (three of them) are all gooseneck.
Psalm 144:1
Stand your ground. Don't fire unless fired upon, but if they mean to have a war, let it begin here. - CPT Parker - April 19th, 1775, Lexington
  #12
Old 08-06-2013, 08:57 PM
Fire in the hole...
Quote:
Hopefully, when you clean out the inside you will find some documentation, such as an owner's manual which might include a receipt with a VIN number.
Hopefully, but no luck so far, and I have gone through every compartment I can find.
Speaking of the inside...
Here is the only real damage that I have found, looks like a little bit of water got in. Will have to investigate.
Psalm 144:1
  #13
Old 08-06-2013, 09:20 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Not bad over all. The seams probably need resealed a they dry out and crack. My neighnor is a RV tech I have watched him work on many that had leaks.
Click for weather forecast
________________
Randy
  #14
Old 08-07-2013, 12:05 AM
fatherdoug's Avatar
What is the name on the front of the trailer?
'78 F-150 Lariat
Quote:
Quote:
  #15
Old 08-07-2013, 07:39 AM
Fire in the hole...
Sierra by Cobra
Psalm 144:1
  #16
Old 08-07-2013, 08:14 AM
fatherdoug's Avatar
Sierra by Cobra is manufactured by Forest River, Inc.
There is one dealer in North Dakota, located in Minot and Bismarck - Capital RV. They might be of some help with a second VIN location.
'78 F-150 Lariat
  #17
Old 08-07-2013, 08:28 AM
taxreliever's Avatar
taxreliever taxreliever is offline
taxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond reputetaxreliever has a reputation beyond repute
Man, that looks like it could be a very comfortable environment camping with......it'll be things like this that we'll look forward to do with the kiddos when they get older....we're enjoying the infant and little toddler stages for now!
Ken
1977 F150 400 AUTO 4x4
1979 F250 400 AUTO 4X4
2006 F150 King Ranch
2007 Expedition EB
www.taxreliever.com
Quote:
Or, as the great Greek philosopher Testiclees once said: "Man who goes through turnstyle in airport is going to Bangkok."
  #18
Old 08-07-2013, 08:55 PM
dustybumpers's Avatar
owned by Fords
I have all 5th wheel on the truck hitches, soory I can't help there.
Sierra Is a good trailer. It will hold up well
Like randy said, you have some seams leaking on the roof. Could be s antenna, or a vent. They make a special self leveling calking for that. Dig out bad seams, clean and apply the new calk.
If you need to get on the roof to work, use a piece of plywood to lie on to spread out your weight, and not case more damage
Charlie
  #19
Old 08-08-2013, 07:49 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Cool Josh....check out Dicor for any roofing needs.
Quote:
Quote:
Quote:
  #20
Old 08-17-2013, 12:59 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
Josh, if you want to find the leak(s) the easy way, bring it to an RV dealer and have them pressure test it. I think the pressure test is $200 and they give you the location of all the leaks. They pressure up the inside (low pressure) and use a glycerin/soap solution down the seams. Makes finding leaks super easy. As Duncan suggested the Dicor self leveling is what you use on the roof. Once it is cleaned and re-sealed, treat it with spic and span, it keeps the roof pliable.
There is a ton of debate on using a gooseneck vs the original pin and frame damage. (read all about it at rv.net) No manufacturers allow gooseneck conversions. I like you wanted the bed space without bars or other crap permanently mounted in the bed. So I went with a B&W companion hitch, I can have it in or out by myself in less than 15 min, without any lifting devices.
Open all the access (storage, fridge, water heater, ect. ect. ect.) openings and look for gaps into the living space of the camper, fill all of those with great stuff foam, it is essential in keeping out bugs and critters.
I recommend checking the dot date codes on the tires and replacing them with LT's as soon as feasible.
Check the brakes and repack the bearings and enjoy.
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
