78 Ranger Trim
Broncodawg
Bleeds Ford blue blood
Might pick up a 78 F150 Ranger and the trim needs to go. Most of it is banged up pretty good and wondering how much of a hassle it is grinding off the mounting tabs? Or are they rivets that need to be drilled out and filled?
No worries, any good trim will be saved and recycled.
Thanks,
:beer:
Most are tabs, and not too difficult to get rid of. There are some pieces held on by nuts...most notably the the front 1/4's...and it'll be easier to take the panel off to get at those nuts. I can't remember off the top of my head where all the nuts are, but I'm sure someone smarter than me will swing in here.
Broncodawg
So, there will be holes to fill and tabs to grind off? Thanks,
Yeah...tons of holes to fill.
3 holes in the front fender, 2 holes in the door and 3 holes in the bed. There are multiple welded on studs that need to be ground off as well.
Broncodawg
Nice trucks boys, have a herd myself, even if all but a 97,7.3 and a 77 trail rig bronco are projects. 58 F100 4x4, 77 F250, 79 F100 old skool prerunner, and well used 79 F350 plow truck. The drivetrain from the 3fitty will be under a bronco or shortbed one day.
This 78 F150 4x4 would give me F100,150,250 and 350 Dents!
Finally, working on getting a bud to part with his clean Cat powered, 79 F600
that I want to build into an eqpt hauler.
Thanks for the tips, see ya back here.
:beer:
Alright...with a list like that, you know you're obligated to post pics right? It's not right to make us drool and run...besides, we all like pics around here.
Broncodawg
All right, twist my arm. :beer:
Wow, I guess there'll be a lot a holes behind the "racetrack".
Thanks,
My bed had all the chrome on it. By the time I fixed all the dents here and there, removed the race track chrome, welded up all the holes, block sanded and block sanded till I couldn't take it anymore. If there is ever a next time I'll just put new 1/4's on it & be done with it.
Broncodawg
Thanks, Can feel your pain. May just pass on the truck as still a fair amount of trimless trucks out there to be found.
