Lots of Ford '73-'79 Parts - Parting out 2 1979 F350's
If I was closer I would get quite a few parts from you.
ie: Brake boosters,brake pedal assemblies,PPV's
Shipping would be too costly though.
Maybe I'll drive down for a vacation ? :)
Well, I picked up a third truck: here's a run down of the truck n misc photo albums I've created for one reason or another..
Remaining parts from first truck:
http://imageshack.us/g/339/p1040071p.jpg/
Plow & flatbed photos on second truck:
http://imageshack.us/g/215/p1040164u.jpg/
Third truck and front of second truck:
http://imageshack.us/g/715/p1040320n.jpg/
Third truck bed and exterior
http://imageshack.us/g/135/p1040352c.jpg/
~~JULY 27TH UPDATE:~~
The third truck: Is a '78 F-250 WITH 55,000 ORIGINAL MILES and has a good running 400M, C6, NP205 and front kingpin dana 60, rear dana 60 both in great shape. It has fender flares, diamond plate stepsides in great shape, good interior, excellent mirrors, good tailgate...and an original bed (finally) but some rot..maybe salvagable. Pass door is best I've had, driver is worst.
Here is my up-to-date parts list from FTE.....I ONLY have what is listed on the parts list..
ATTENTION BUYERS: EVERYTHING ON THE PARTS LIST IS NOW HALF OFF with the exception of the trans. I AM MOVING (in May) AND LIQUIDATING EVERYTHING. $50 MINIMUM, BUY EXTRA.
In an attempt to inventory the parts I have here is a current running list of nearly all of the parts. Feel free to inquire on anything else. Understand that I have NOT had any 1/2 ton specific or 2wd specific parts. All 4wd F-350's and F-250 snowfighter..
Everything on this list is current and available:
NP435 4-speed trans out of running & driving f-350 custom complete with frame/bellhousing mounted linkage, shift fork, throwout bearing, shifter, shifter boot & Hurst shifter handle
Good 11" clutch and flywheel used with 400 motor but originally from 351m motor
Front Dana 60 part-out including gears, carrier, cover, steering arm, hubs, yoke etc (NO HOUSINGS OR COMPLETE AXLES, see other ads)
Set of (4) original 16.5" steel wheels
31"x10.50x16.5 used tires and wheels
NEW ignition parts (almost the entire ignition, coil, relay, distributor etc)
Holley Carb from 400 motor (model 4150/4160, 390cfm street/strip carb)
Edelbrock Performer 400 intake
good fuel tank complete with float assembly
filler neck
hood latch assembly
transmission cooler and radiator
auto transmission linkage from column
NP205 transfer case shifter, shifter knob and chrome trim around shifter boot (NO cases or 4wd shifter boots)
Speedometer cable
Manual steering column complete with levers
Steering wheel
Front CV driveshafts
Rear driveshafts
1-ton tie rod
160A High Output alternator!
transfer case heat shield from snowfighter
transfer case sandwich frame mount
front grill mount brackets (3) and all hardware
3-piece transmission/transfer case crossmember complete with hardware
rear f-250 snowfighter leaf springs
Solid (no rot) V-Force dual exhaust complete with hangers/flanges from single cab copper colored truck
all exterior chrome trim from cab forward
front dana 60 u-bolt brackets (top and bottom)
rear dana 60 u-bolt brackets
Rear Leaf spring blocks
Rear Leaf spring blocks with bumpstops
throttle kickdown rod with c-clips for auto trans
used starters in good condition
Good windshield complete with rubber and chrome trim in good condition
Rear glass with sliding windows complete (with good rubber)
EXCELLENT condition front radiator core support/front bumper/fender support
Black sun visors
100mph guage cluster from F-350 Custom
80mph guages (3 different ones from F-350's & F-250 lariat snowfighter)
Ignitions with keys
White hood with NO rot in great shape
Chrome Front Bumper - good
Hood hinges, mounting tracks
Tailgate hinges
Left tail light
Upper and lower door hinges
Windshield wiper arms
Chrome step trim inside door on floor
Tail light chrome trim
Blue seatbelts
White glove box door
Ford dog-ear reversible mirrors needing new glass from F-350
Red, white, blue or black ash trays, original cigarette lighters
Chrome door pulls
Plastic door lock pulls
Window cranks with black or clear plastic knobs
F-250 Custom badges
F-250 Ranger badges
F-350 Custom badges
XLT badges
I'd be interested in pics and/or prices of the following:
steering wheel
wiper arms
XLT badges
'dog ear' mirrors
