  #11
Old 08-27-2020, 10:00 AM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
Originally Posted by Sparky83 View Post
they didnt have the right size so they had to transfer the old one to the new rim.... the biggest concern with reusing the old ones is if the seal doesnt reseal to the new one... usually you dont take the old ones off unless you can replace the seal... they didnt even have the seal to replace either... the shop it went to does alot of tractor trailers and tractors... (heavy equipment)... they thought they had some that would fit but didnt... they offered to put in a snap in high pressure stem but everything ive heard of for these trucks is they need the bolt on ones...
Oh man!
Roy
yeeooow!
  #12
Old 08-29-2020, 11:46 PM
Sparky83's Avatar
Sparky83 Sparky83 is offline
And to add to the new list. Found out during closer inspection of the truck And its brakes i found that both front hub unit bearings are leaking grease again. So now those have to be replaced. If i was still running around town with it i wouldnt care. But just over thousand mile round trip while pulling trailer im going to play on the side of caution and just replace them. But least i got the rear brakes finally adjusted to hold the truck on a hill.
Also picked up some gear lube for both the front and rear diffs. Rear just needs topped off from having the half shafts out. Front i plan to change it out since i dont know when it was last done. And looks little milky. But the front will wait for another day.
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #13
Old 08-31-2020, 11:41 PM
Sparky83's Avatar
changed out the hub assemblies on the truck. The spiney freey anti metal rubbie juice came out. pass side not to bad. But driver side was totally covered. Along with the inside of the rotor hat.
pass side
driver side one
got them changed out Then went to try and refill what came out when i had the halfshalfs out to adjust the drum brakes. Apparently between the times ive had them out i lost 1-1/2 bottles of fluid. Had only bought one the day before.  So had to get another to finish topping it off.  So now the rears full again.
Shawn
-John F. Kennedy
-Christopher Titus
  #14
Old 09-15-2020, 06:47 PM
Sparky83's Avatar
i go to lock the front end up so i can hook the trailer up for my trip tomorrow only to discover the truck has a surprise for me...
it blew the hard line for the brakes just behind the flex joint on the line going from the ABS manifold to the back of the truck...
Shawn
-John F. Kennedy
-Christopher Titus
  #15
Old 09-20-2020, 09:36 PM
Sparky83's Avatar
 got the lines swapped out and the brakes bled on the truck tonight. The first pic is just comparison from the old line to the new one. The second pic is of the hole where the brake fluid was escaping.
had the line changed out in about 30 mins. Finished the bleeding after the sun had completely set. Will work on replacing the rest of the hard lines shortly. Safe enough for right now. But want to work on replacing the rest for peace of mind.
Shawn
-John F. Kennedy
-Christopher Titus
  #16
Old 09-21-2020, 11:49 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Wow if its not one thing its another
Click for weather forecast
________________
Randy
  #17
Old 09-22-2020, 08:30 PM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud of
Glad you found that while it was sitting still!
I've had 3 different brake line failures and a caliper failure while moving and it's not fun.
- Russell
'77 F100 Flareside
