Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Early Bronco
Early Bronco 1966-1977
  #1
Old 08-24-2015, 11:06 PM
Bigbeardbiii's Avatar
Bigbeardbiii Bigbeardbiii is offline
Bigbeardbiii is on a distinguished road
'73 Runs now but way to rich (6 MPG) & Tranny shifts way too Fast!!
My '73 Bronco is currently getting 6 mpg & the auto. tranny is not shifting correctly. It seems to be running way too rich. This morning I could smell pure gas when standing beside it running as well as when raising the hood but no leaks! This weekend we just replaced the dizzy, points (After replacing the points in the dizzy over the weekend, it would finally run), plugs & wires, carb (rebuilt original Motorcraft from Guaranteed Carburetors), coil, timing chain & gears, water pump, radiator & hoses, thermostat, 13 gallon gas tank & line (Only 1 tank (rear)). I have no idea what mpg it had previously as I recently purchased it, & new tranny fluid & gasket. We thought we had it retarded 6 degrees from TDC but this morning after cranking it up it sputtered in idle and went dead when putting in reverse but would crank back up and run but had a loping sound to it. So, this afternoon we retarded the time a little more and adjusted the idle and now it goes into reverse without sputtering or stalling but still makes the "clunk" noise when initially putting into reverse, & runs as smooth as a sewing machine except for the auto tranny shifts from 1st to 2nd within 3 seconds (around 5 mph) of putting in drive and shifts to 3rd withing 3-5 seconds thereafter (around 10 mph). However, has plenty of power and when punching it on the open road it has a lot of power (like a passing gear but you can't hear or feel it shift it just speeds up ( got up to 90 mph today).and runs as smooth as a sewing machine except when backing out of garage (when initially putting into reverse it makes a "clunk" and slight quick jerk as going into reverse. I don't know if retarding it to be more precise will fix the mpg issue or not (again, it was late in the eve before we adjusted it)? Also, I don't understand why it shifts from 1st to 2nd and then to 3rd all within 10 seconds or so without punching the gas. The passing gear bar going from the tranny to the throttle linkage was not connected when I purchased it. It has slight scrape marks that would perfectly match-up to it being connected on the lowest part of the throttle linkage but the end of the spring that goes in that hole is not long enough to also hold it in place.So, what I did was place it on the pin coming out the top left side of the throttle before placing the arm there that has the ball on the end that clips it to the end. I don't think that is the correct place for the passing gear bar & therefore, don't know if that is contributing to the shifting issue or not (?). Lastly, again I have installed a reman. Motorcraft carb. I have the two vacuum lines from the dizzy connected to the ports they went to one the previous carb. but there is a threaded port on the rear passenger side of the carb that sucks air and I don't see what, if any, hose, etc... goes there. I have created a file of pictures in the gallery: 1. is of the rear of the carb. (is a circular factory part just behind the carb with two hoses connected to it(1 is cut off about 2" from part & the 2nd one runs about 2' but is plugged on the other end), 2.is of the threaded tit that sucks air constantly while running but do not see what, if anything, should be connected to it, 3. is of the throttle linkage and shows the passing gear bar connected to the top, & three shows the passing gear bar as it rides above the engine to the throttle linkage. Any assistance would be greatly appreciated as I am out of ideas& my element with these things. Thanks, Dean
[/SIGPIC]Blue '73 Bronco Ranger (STOCK), Auto., PS, 5.0
Black & Tan '95 Bronco Eddie Bauer, Auto., PS, 5.0, Brush & Grill Guards, Fog Lights
  #2
Old 08-25-2015, 06:16 AM
dustybumpers's Avatar
Might have a High gear ratio, which would make the transmission shift like that, and make the mileage bad, and the engine is running at it's limit all the time.
If the idle is too high, it will make the drivetrain clunk when it goes into gear
Vacuum leaks will make an engine idle high, and smell like a gas leak, find the vacuum leaks.
It would be easier to help you if you broke up your posts into sentences and paragraphs
A lot of people won't read a big mass of print, too hard to decipher what you are trying to ask
Charlie
  #3
Old 08-25-2015, 09:43 PM
Charlie,
I apologize for the thread post not being broken into paragraphs. I had them indented but when I submitted it put it all together. I am going to add again by adding lines of dead space between paragraphs. Hopefully, that'll work.
This weekend we just replaced the entire dizzy , points (After replacing the points in the dizzy over the weekend, it would finally run), plugs & wires, carb (rebuilt original Motorcraft from Guaranteed Carburetors), coil, timing chain & gears, water pump, radiator & hoses, thermostat, 13 gallon gas tank & line (Only 1 tank (rear)). I have no idea what mpg it had previously as I recently purchased it, new tranny fluid & gasket, & adjusted the idle & thought we had the timing set to 6 degrees BTDC.
We thought we had the timing set to 6 degrees BTDC but this morning after cranking it up it sputtered in idle and went dead when putting in reverse but would crank back up and run but had a loping sound to it. So, this afternoon we moveded the dizzy about a 1/4" to adjust the timing a little more and adjusted the idle and now it goes into reverse without sputtering or stalling but still makes the "clunk" noise when initially putting into reverse, & runs as smooth as a sewing machine except for the auto tranny shifts from 1st to 2nd within 3 seconds (around 5 mph) of putting in drive and shifts to 3rd withing 3-5 seconds thereafter (around 10 mph). However, has plenty of power and when punching it on the open road it has a lot of power (like a passing gear but you can't hear or feel it shift it just speeds up ( got up to 90 mph today).
I don't know if us adjusting the timing to be more precise will fix the mpg issue or not (again, it was late in the eve before we adjusted it)? Also, I don't understand why it shifts from 1st to 2nd and then to 3rd all within 10 seconds or so without punching the gas.
The passing gear bar going from the tranny to the throttle linkage was not connected when I purchased it. It has slight scrape marks that would perfectly match-up to it being connected on the lowest part of the throttle linkage but the end of the spring that goes in that hole is not long enough to clip into the hole and also hold the passing gear bar in place. So, what I did was place it on the pin coming out the top left side of the throttle before placing the arm there that has the ball on the end that clips it to the end. I don't think that is the correct place for the passing gear bar & therefore, don't know if that is contributing to the shifting issue or not (?).
Lastly, again I have installed a reman. Motorcraft carb. I have the two vacuum lines from the dizzy connected to the ports they went to one the previous carb. but there is a threaded port on the rear passenger side of the carb that sucks air and I don't see what, if any, hose, etc... goes there. I have created an album of the pictures in my garage: 1. is of the rear of the carb. (is a circular factory part just behind the carb with two hoses connected to it(1 is cut off about 2" from part & the 2nd one runs about 2' but is plugged on the other end), 2. is of the threaded tit that sucks air constantly while running but do not see what, if anything, should be connected to it, 3. is of the throttle linkage and shows the passing gear bar connected to the top, & three shows the passing gear bar as it rides above the engine to the throttle linkage. Any assistance would be greatly appreciated as I am out of ideas& my element with these things. Thanks, Dean Her's a link to better photo's: http://www.supermotors.net/registry/27354[/URL]
  #4
Old 08-25-2015, 10:19 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
If you have a port sucking air, there is a vacuum leak that needs at minimum capped. From what I can tell, the EGR is not hooked up at all. The open port will cause a massive fuel mileage issue to start with.
My trucks:
  #5
Old 08-25-2015, 11:16 PM
Charlie & Fellro,
I just went out to inspect the lines to the tranny & added a few more pics to the link added to last post that contain the two lines from the rectangular metal box that has several lines running from it. The outer/upper line goes from the driver's side of the box down toward the tranny but is capped off on the end by a screw. The inner/lower line connects to the box on the top & connects to the rear of the two tits located on the passenger side of the tranny (it was barely connected from the rubber rotting off around the tit so, I cut the rot off & connected it tightly. Should the outer/upper line be capped off like it is & the front most of the two tits on the tranny just be open as it is?
  #6
Old 08-25-2015, 11:17 PM
Quote:
Fellro,
I capped off the other lines on the EGR too.
  #7
Old 08-26-2015, 06:14 AM
Like I said in my earlier post, you may well have a low gear ratio, which would make the truck shift quick like that.
I have 4.88 gearing in my one truck, it is in 5th gear by the time it hits 35 mph
I am posting from my tablet at the moment, when I get to my laptop, I will look at your pictures, and see what you have going on
Thanks for spacing out the thread question, it makes it a whole bunch easier to maneuver
Charlie
  #8
Old 08-26-2015, 09:18 AM
Charlie,
Thanks. However, in your initial thread you stated mine might be geared high but in your 2nd post you stated that you originally stated that mine might be geared low. All I know is that it is all factory as the only thing that's been altered is a 2-1/2" lift in the rear. Is there somewhere I can locate the gear ratio? Thanks again & I hope you get a chance to review the pics soon as we are planning to get together to do whatever we can to fix the problems at 2:00 p.m. (CST) today.
  #9
Old 08-26-2015, 05:02 PM
jebadiah04 jebadiah04 is offline
Rooster Snorkler
jebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud ofjebadiah04 has much to be proud of
i responded to your other post about the transmission shifting issues. i say vac leak
1985 f-150 flareside
2008 f-150 crew cab
2005 f-350 Crew Cab Long Box diesel - for sale. Check out my classified post!
  #10
Old 08-26-2015, 07:13 PM
Quote:
Originally Posted by Bigbeardbiii View Post
Charlie,
High was meant to be low, as a high number ratio.
You have an awful lot of open vacuum lines in those pictures. each line has a purpose. You will need to either block them off, or hook them to where they belong. Take the air cleaner off, and shoot a picture straight down of the motor
I also see the PVS hose and valve look old and needing replaced. that is a good start ( passenger valve cover in the back)
Do you have a power brake booster on this truck?
Charlie
Tags
carburetor, mpg, transmission
