2003 Windows will not work
Hello, I am having trouble with my 2003 Ford Explorer XLS windows. I have replaced the master switch on the drivers side door, the 30 amp fuse under the hood and checked for other blown fuses. When I check the current through the 30 amp I have power on both sides. When I check the wiring at the switch nothing is hot even with the ignition switch in the on position. Any idea? I cant find a wiring diagram so I am not even sure which wire to the switch is suppose to be hot.
Any help would be greatly appreciated.
Thanks in advance,
Tony
CowboyBilly9Mile
442
USA
..I cant find a wiring diagram so I am not even sure which wire to the switch is suppose to be hot.
Thanks in advance,
Tony
Read my siggy. ;)
