Go Back   Ford Truck Fanatics > Special Interest > Off-Road
  #1
Old 12-19-2013, 08:24 PM
LEB Kris's Avatar
LEB Kris LEB Kris is offline
Kris
LEB Kris is just really niceLEB Kris is just really niceLEB Kris is just really niceLEB Kris is just really nice
LEB - George v4.0
Well, I just finished the engine so I guess I might as well continue the build here in the offroad forum.
Engine build
http://www.fordtruckfanatics.com/for...ad.php?t=35756
79 F250 521/c6/205 60/60 4.56 detroits front and rear.
First things first. Getting ready for v4.0.
4" 77.5-79 front springs -
Safety first kids
Get that junk out of there
4" 99-04 Super Duty gas springs vs 4" 77.5-79 250 springs
ORU zero rates 1.5" forward position
4.5 vs 6 shackles
Drill out your front hangers for a 18x130mm bolt
Bolt it up. Its just that easy
U bolt flip since youve got the axle out
Make a front receiver hitch while youre at it
New trans crossmemeber
Quote:
Disclaimer: Kids, mixing high strength pain killers and alcohol is very, very bad for you. Don't do it. If you do, tell your parents Kris (STG) told you about it.
  #2
Old 12-19-2013, 08:41 PM
LEB Kris's Avatar
Kris
Front and mid motor plate mock up
mid plate
Front plate
Front mounts
Crossover and highsteer 1.5 x .250 DOM with Chevy 1ton tres
LEB Paul had my other arm when this pic was taken
  #3
Old 12-19-2013, 08:58 PM
LEB Kris's Avatar
Kris
Tilt front clip
Front hinge tacked on
Hinge
  #4
Old 12-19-2013, 09:08 PM
LEB Kris's Avatar
Kris
Fuel system
Sump in the stock tank, -12 to pump, 5/8 aluminum fuel line to the firewall, -10 to regulator
Aeromotive A1000 pump
Filter
Holes for baffles
Welded in a sump
Some cutoffs and -12 outlet
-8 return line fitting
  #5
Old 12-19-2013, 09:36 PM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
How long ago did you do all this fabrication? Did the geometry work out well on the shackle?
  #6
Old 12-19-2013, 09:44 PM
LEB Kris's Avatar
Kris
Ummmm.....
eerrrrr.....
well.....
The first pic was taken in 2009 and I just finished the engine today. Most of this stuff has been a very slow work in progress over the past 4 years.
The shackle is slightly kicked back (maybe 5* off vertical) with no weight on the front at all. I assume I will be close to 20* off vertical under full weight.
  #7
Old 12-19-2013, 10:00 PM
I was playing around with the leaf springs on my 1994 at one point and I wasn't ready to commit to moving the shackle hanger. I was just curious, not a trick question.
  #8
Old 12-19-2013, 10:14 PM
LEB Kris's Avatar
Kris
Longer shackles will only work if the springs are also longer. Otherwise your angles will get goofy
  #9
Old 12-21-2013, 12:36 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
Hey, you're further along with your build than other forum members.
How soon till you're back in the mud?
Пробковыйy
  #10
Old 12-21-2013, 01:43 PM
Austin's Avatar
Austin Austin is offline
Austin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond reputeAustin has a reputation beyond repute
Quote:
Originally Posted by 1970Custom View Post
Hey, you're further along with your build than other forum members.?
I could name a few.
Quote:
Everyone is my teacher. Some I seek. Some I subconsciously attract. Often I learn simply by observing others. Some may be completely unaware that I'm learning from them, yet I bow deeply in gratitude.
