  #1
Old 05-07-2012, 12:19 PM
StoryBoyof94's Avatar
StoryBoyof94 StoryBoyof94 is offline
StoryBoyof94 is on a distinguished road
1978 F100 "Rooster"
I have a 1978 Ford F100 4x4 with a 1992 Big Block 460 im building. Im wanting to make a custom gauge, how hard is it to hook up a sunpro speedo?
[><]SOUTHERN PRIDE[><]
1979 Ford Bronco "BOSS HOGG"
  #2
Old 05-07-2012, 05:36 PM
Mil1ion's Avatar
Mil1ion Mil1ion is offline
Mil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond reputeMil1ion has a reputation beyond repute
Easy 4 wires
Blk -grd
Bue - light
White- tach signal
red - Power
A LEO born in the year of the TIGER,so don't mess with ME
I speak in "Straight Talk" Deal with it.
Click for Red Deer, Alberta Forecast
  #3
Old 05-07-2012, 07:47 PM
work on the stock cable?
  #4
Old 05-08-2012, 06:30 PM
Mil1ion's Avatar
Explain stock Cable ?....
The Tach has 4 wires
red to power (Under dash)
Blue > Light (Connects Under dash)
Ground > (Connect under dash)
White > Signal..run to TACH (-) terminal to coil
  #5
Old 05-08-2012, 06:40 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Coz he was asking about a speedo.......
Quote:
Quote:
Quote:
  #6
Old 05-08-2012, 09:11 PM
Mil1ion's Avatar
Stupid me ..............
I think Tach
What will the electronic speedo use as a rpm sender ?
There isn't any Electronic speedo signal source and the 78-79 uses the OEM speedo cable/with cable sensor.
You may ave to rob the system from a newer truck with sensor on the driveshaft or transmissin
  #7
Old 05-08-2012, 09:12 PM
yea. i could do the tach easy, i was asking bout the speedo. will the stock cable work on aftermarket speedos?
  #8
Old 05-08-2012, 09:38 PM
DNFXDLI's Avatar
Admin
Best check with the manufacturer of the speedo, I recall in the old days, some worked and some didn't.
  #9
Old 05-09-2012, 09:50 AM
im buying a sunpro speedo and i was hopeing it would work in the stock cable but ti think its all electrical, so ill have to buy an adapter kit
  #10
Old 05-09-2012, 10:07 AM
thanks for all the help guys, i found a auto meter speedo that will work on my stock cable.
