Go Back   Ford Truck Fanatics > Engines > 289, 302, 351W
  #1
Old 06-11-2017, 03:24 PM
donnchad donnchad is offline
donnchad is on a distinguished road
Distributor driven directly from crankshaft or via camshaft/chain???
For 351 1990 5.8L V8 EFI engine is the distributor rotor driven:
(a) directly from crankshaft?????
OR
(b)Is it driven from chain driven camshaft?????
  #2
Old 06-11-2017, 06:38 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Camshaft is driven by the crank by chain at 1/2 rotation, which then drives the distributor
My trucks:
  #3
Old 06-11-2017, 07:43 PM
Quote:
Thank you. So you are saying (b) is the correct answer???
  #4
Old 06-11-2017, 08:13 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Yes B would be correct
-Frank
Quote:
What's your view on sheep?
  #5
Old 06-12-2017, 12:01 AM
It would be best to direct drive from crank. Chains are never great. Why not do all timing using gear drives direct from crank??? More accurate and less wear and noise?????
  #6
Old 06-12-2017, 06:37 AM
Fellro's Avatar
Admin
Location, location, location... If you crank drive it, the distributor then has to be down low, generally in front. Also, the distributor relates more to valve opening than piston location really. The distributor needs to turn at half the rate the crank does, as does the camshaft, so the gear reduction is also already handled. Can you imagine the size the gear would have to be to get a 1/2:1 reduction?
My trucks:
  #7
Old 06-12-2017, 09:42 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
Quote:
It's been done, it was in a line of Chevy str8 sixes from the early 60's known as Turbo Thrift and yes, noise was one of the concerns with the two-gear setup. The best solution actually is a direct drive from the crank, it's been done for several years now, it's what technology delivered (eliminated wear parts replacement, eliminated an assembly altogether, no timing adjustment needed/accurate timing over life of vehicle, improved driveability, emissions, etc) and the benefits of mass production (low cost) put in the publics hands, this solution is known in the Ford world as EDIS.
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #8
Old 06-12-2017, 10:43 PM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
my old truck had the distributor run right off the crank... imo it was the most annoying thing possible... straight 4 and the distributor was buried under the intake... only way to access it was through the wheel well and even then you were working on it in the blind since you couldnt see it once your arm(s) hands were in there... least on the V-cyls engines with the distributor on top and running off the crank you can atleast see what your doing.. makes the job 100000000x easier when trying to get the timing set right...
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
