A 6 Litre Mod?
flareside_thunder
7,812
246
Anyone heard of this? Seems to be pretty popular with the FSB guys...not sure if it'd actually change anything or not though....
Okay, so here's another write-up of an easy job, for which there is no write-up.
I just did the "Sixlitre" ignition upgrade and timing bump to my `94 5.0. Here's how:
Start by buying the wires, cap, rotor, and coil. These are the parts for a `94 5.0:
flareside_thunder
7,812
246
(To be entirely accurate, the wires shown are for *most* `94 5.0s. They happened to be wrong for mine, which for some unknown reason took the wireset for a Lightning 5.8 HO.)
You'll also want some cheap copper sparkplugs (Motorcraft are fine.)
Next, disconnect the negative cable on your battery.
Unscrew and unplug the old coil. Mine took a 5.5mm wrench.
Here's the empty coil bracket.
And here it is filled with bright red goodness. This just drops in, and plugs right back into the same place as the old one.
Since I'm paranoid about making too many changes to a system at once, I re-connected the battery after changing the coil and fired up the engine, just to make sure it started. Remember to disconnect the battery again.
(It's a lot easier to work on the cap and wires if you take off the intake tube. Mine's MAF, so I had 2 hose clamps on the throttle body, one on the air cleaner box, and one on the back of the oil fill neck. YMMV.)
Remove your tired old distributor cap by unclipping the (rusty) spring clips on the sides. There are two of them. The one on the right is shown unclipped here.
Underneath is your rotor. It lifts straight off the shaft, which is keyed so the new one only goes on one way.
Again, paranoia. I transferred all my old wires to the new cap, and started the truck again, just to be sure.
I use liberal amounts of dielectric grease in my spark plug wires, so I buy big tubes of it. Works as brake caliper lubricant, too.
Some of the original wire looms are very hard to deal with. This one, for the 7&8 pair of wires, is mounted on a stud next to the valve cover. If you grab it with a pair of pliers, and pull it directly parallel to the side of the valve cover, it'll pop right off the stud, then you can open it. There's another just like it on the other side for the 3&4 cylinders.
You're supposed to do the plug wires one at a time, so that you don't get them mixed up. That didn't work for me, all of them were too long, and if I went with what fit the first 4 or 5, I ended up with wires that were a foot or more too long. I ended up pulling off all 8, sorting them by length, then sorting the new ones by length, and matching them up that way. When you're putting them back on, remember that cylinder 1 is the front cylinder on the passenger side, and 5 is the front cylinder on the driver side.
As I replaced the wires, I pulled each plug and re-gapped it to .055 inches. No pics, sorry. It's not that hard, though a universal joint, a selection of extension lengths, and some caution so that you don't cross-thread the head when re-installing them are all good ideas. I had just put these plugs in, they were platinum motorcrafts that I didn't want to throw away. With this ignition setup, though, plain copper Motorcrafts would work fine, and as long as you are doing all these changes, put some new plugs in. The .055 gap is what we're doing all this stuff for anyway.
edit: Here's pics and how-to for the spark plugs: http://www.fullsizebronco.com/forum/showthread.php?p=1086609
Here's the end result of the too-long set of wires. Pretty, no? No. I didn't think so.
Taylor told me what part number to get, and Summit sent out the Lightning 5.8 HO set, which fits *much* better. (Note: I also replaced several of the wirelooms with some from Mr. Gasket.)
Okay, the reason we did all that work was to get the fatter spark from the new coil jumping that longer (.055 vs. .042) gap, so that we can bump the timing up a bit and get a little more power/efficiency. So, here's how to set the timing on the 5.0:
First off, for those who don't know, timing is what controls when the sparkplug fires in comparison to where the piston is in the cylinder. You want it to fire while the piston is still compressing the fuel-air mixture, just before it starts going back down. When the piston is at the very top of the stroke, that's called Top Dead Center (TDC). Normal base timing for the `94 5.0 is 10 degrees BTDC (Before TDC). That means that the sparkplug fires when the crank still has 10 degrees to turn before reaching TDC. That's what the factory chose for the most efficient burn. With this enhanced ignition system, we can fire even earlier than that, and burn even more of the fuel, more completely.
First thing to do is to make the timing marks readable. There are two parts to the timing marks: The degree marks on the harmonic balancer (on the front end of the crankshaft, behind the main pulley), and the pointer (fixed to the block). We'll make the degree marks readable first. Get out your remote start switch, and connect it across the starter solenoid.
Edit: The above picture is the WRONG way to hook up the remote starter. Your remote starter switch's wires will melt, since all the draw of the starter is going through the switch. Here's the right way:
One of the connectors is on the +12 pole, the other is on the energizing contact (pull off the small wire at the top of the solenoid, hook up there). You can see the connector I pulled off near the tapered end of the red connector (the black L shaped thing). Thanks to collinsperformance for pointing out the error of my ways. end of edit
Disconnect the coil wire so the engine won't start.
While you're at it, put the parking brake on, chock the wheels, and make sure the transmission is in Park (neutral if a stick shift).
Stand off to the side and hit the remote starter switch a couple of times, make sure that the engine turns over *without* the truck leaping forward and crushing you to death.
Put on some eye protection. I like the faceshield because it keeps the rust out of my mouth.
Once you're pretty sure you're not going to kill yourself, crawl under and lay on your back under the front of the truck. Feed the starter switch down to where you can use it (keeping the cables out of the belt and fan), and bump the engine around until you can see the degree marks on the harmonic balancer.
Make them visible. You could clean and paint them (what I wish I'd done), or you could put on a timing tape, like I did. (I only used part of it, because I couldn't get it all on, and only needed part of it.)
flareside_thunder
7,812
246
Go back up top, disconnect the remote starter switch. Reach in with a paint pen or a q-tip or something and paint the end of the pointer. (For reference, at the top of this picture is the bottom of the idler pulley, at the bottom left is the top of the tensioner pulley, and at the bottom right is the top of the water pump pulley.)
Okay, now that the marks are visible, we'll get to the actual timing. Up and to the right of the last picture is the distributor clamp bolt. It's a half-inch on mine.
I used this nifty dogleg wrench to turn it.
Don't loosen it yet, though, we need to warm up the engine. Put everything back on that you took off (neg battery cable, coil wire, intake tube), and fire it up. Let it get up to normal operating temperatures. Wait for the thermostat to open (when the top radiator hose goes hot). Shut it down.
Find your SPOUT connector. Here's mine, the light gray thing in the red circle. That thing above it is the cruise control servo. It's in the rear driverside corner of the engine compartment. Just unlatch the latches, pull the gray tab out of the connector, and put it somewhere safe.
Hook up your timing light. It gets its power from the battery, and picks up its signal from the #1 sparkplug wire. Here's the power hookup:
And here's the signal pickup clamped around the #1 wire:
(a little hard to see, but it'll be obvious when it's in your hands)
Watch your wires so they don't get into the fan or belt. Point the timing light at the timing pointer, start up the engine, and the strobe light in the timing light will fire every time the #1 cylinder fires, "freezing" the view in place so that you can read the timing setting. (You'd be amazed how hard it was to get this shot with an auto-focusing digital camera.)
Shut down the engine. Loosen the distributor clamp bolt that we discussed earlier, just enough that it allows the distributor to turn. Rotate the distributor (just grab it by the cap and turn it) clockwise to advance the timing (advance means go further BTDC, so 11 BTDC is 1 degree advanced from 10 BTDC). You're shooting for about 13 or 13.5 degrees. The picture above shows 13 degrees.
Start up again and check the timing. Shut down and tighten the clamp bolt back down when you've got the timing where you want it. Here you can see how little we actually turned the distributor (small white mark used to be under the clamp bolt).
The bolt doesn't have to be super tight, just enough so that the timing doesn't change on its own and the bolt doesn't loosen on its own.
Put the SPOUT connector back in. Check all your connections and make sure that you have re-attached everything you detached.
Take it out for a spin. Hopefully your mileage and performance will both be improved.
That's a really detailed writeup Junior. Like you say it's simple stuff that a lot of people know but of course it's useful for people who are uninformed.
One note: with the MSD coil and gapped plugs, it's best to use a 9mm wire set (Ford Racing makes one) to help carry the fatter spark to the plugs. 8mm plugs can act as a bottleneck in the system when using the MSD blaster coil.
Otherwise-- seriously awesome writeup. I'm very impressed with the detail.
TexasNomad
FTFS Designated DRINKER!
Ok Hommie! I wonna see some Dyno numbers! so enough all the long winded BS! come on chop chop!
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
thats basically what i did to my old truck.. msd cap /coil.. racing wires.. plugs gapped to 0.55 and 14 BTDC timing.. and i gotta say its a noticable difference in power!!!
i did those after i did my exhaust soo i really felt the extra power..
went from 0-60 12 seconds stock
to 0-60 9.5 seconds exhaust and those things
So, Flareside Thunder(AKA Tex), pardon my ignorance, but what is a "spout" connector? Excellent writeup. I'd give reps, but I don't know who to give them too....
That's a great article for the pics and detail, but the author must be obsessive compulsive because he makes this job way harder than it needs to be.
There's no need for the remote starter at all, just put a socket on the crank bolt and turn the engine over by hand, it's a lot safer than lying on your back under a vehicle and bumbing the engine with a remote start? Where did he come up with that bright idea?
And all the starting and stoping the engine after every little step. Why make it so complicated. Just setup the damn timing light and loosen the dizzy slightly. Start the motor and then pull the SPOUT, set the timing, snug the dizzy, recheck timing to make sue it hasn't moved while you're monkeying with the distributor, and plug the SPOUT back in. Done.
nobodyspecial
Fire in the hole...
5,756
366
ND
For me, the MSD coil is crap. That thing is the reason for the only time my truck left me stranded. I replaced my coil, plugs, cap and rotor and everything was great until that MSD coil crapped on me with less than 2000 miles on it. I replaced it with a stock coil, and have had no problems since.
Paul a lot of times that won't work because the 10* mark won't be marked with chalk/paint when you buy the truck (mine wasnt). Furthermore, this mod requires ~13 btdc which DEFINITELY isn't going to be marked unless the previous owner set it to that timing for some reason.
To be honest-- the point of the article is to help people understand the underlying concepts here and if they want to take shortcuts I think it's pretty obvious where those shortcuts can be taken.
The SPOUT (spark output) connector is just a jumper that completes the circuit for automatic timing advance built into the distributor/computer. If you leave it connected and try to set the base timing, you'll could be looking at the wrong timing because the computer could have already advanced/retarded it. So you pull the SPOUT and it breaks the circuit to force your timing to base timing.
Hey don't get me wrong I meant it when I said the article was great for the pic and details, a novice would definitely be able to complete this task with all that info. I just didn't like his use of the remote starter.. it's needlessly dangerous and unnecessary when a breaker bar and deep socket would do the same thing. I know what you mean about the timing marks on the balancer too, I have to clean mine with some sand paper and rub chalk into them to make them visible. Also if you have a timing light with the advance control built in then you can dial in whatever amount of advance you want on the gun and then you just have to find the TDC(0) mark.
Yeah I know what you mean about the remote starter. I've cranked on the crank pulley with a breaker bar... It works but damn on a hot day IT AIN'T FUN! :rofl:
Hey that's neat!
