Bought New Hub Locks
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
Finally broke down and bought myself new hub locks for my truck... Factory ones have pissed me off one too many times now.. tried regreasing them twice... and now theyre freezing up again.. tired of messing with them.. Pass side hard to turn even when its loose... when its not loose its close to frozen.. On top of that they wouldnt release either when i switched them back to Free the last couple times.. the very last time i smacked them with a hammer a few times to get them released..
So finally bit the bullet and bought me some aftermarket ones.. No plastic parts in the new ones like their are in the factory ones.. So cant wait till they get here... hopefully i can get them before the weekend so i can get them in over the weekend..
smokey
Hitech hillbilly
Hubs that turn hard and stick are the pits.
I was religious about hub greasing and replacing them on my trucks. When you need 4 wheel drive you want them to work.
Sparky83
5,571
226
Norlina NC
exactly.. mine get so hard to turn it actually hurts the hand to turn it.. i had that problem a couple days ago despite using them not even a month ago... then when i tried to get them to unlock they wouldnt... had to jack the front end up and smack them with a hammer a couple times till they popped free...
smokey
Hitech hillbilly
I even made a pin wrench years ago that fit the hubs to help to turn them.
I kept in the bed box just encase I ever needed it. Used it on friends trucks often and mine once or twice when they iced up and when frozen with ice.
Sparky83
5,571
226
Norlina NC
hmmm never thought of doing that...
Sparky83
5,571
226
Norlina NC
my phone texted me... 10:01 AM and i dont get off work till 5...
unfortunately i wont be home till after 9pm :(
Sparky83
5,571
226
Norlina NC
These are one of the main reasons I bought my Super Duty. Manual t-case and hubs,
mines a mannie and mannie too.. but stupid factory hub locks are going...
Sparky83
5,571
226
Norlina NC
^^^ funny they include them... dont they know we men dont read those things lol
another piece of advertising for the box...
1970Custom
They call me Spuds
14,107
447
Middleton, ID
My pickup has way more options than I really wanted, but to find manual 4x4 on everything else I looked at meant manual windows and doors as well.
Where'd you get the hubs from? Are they quarter turn or full turn lockout?
Sparky83
5,571
226
Norlina NC
1/3 turn... Summit Racing..
http://www.summitracing.com/parts/yga-29085/overview/
Rounding off $386 for the pair...
they were like the only aftermarket company that claimed to not have any interference issues with the dually spacer up front... will find out this weekend for sure..
https://www.yukongear.com/productdetails.aspx?ProdID=11868
Why did you go with Yukon? Never mind. I think you answered the question in the previous post. Warn hubs have interference issues?
Sparky83
5,571
226
Norlina NC
they were like the only aftermarket company that claimed to not have any interference issues with the dually spacer up front... will find out this weekend for sure.. plus they have a pretty good reputation in the 4wheeler crowds..
Sparky83
5,571
226
Norlina NC
ill tell ya the instructions are wrong... this is not something 1 person can do.. you need an assistant to help.. especially when your putting the retaining snap ring in...
I did manage to figure out why the pass side spacers always a PITA to get off
This is the driver side... it has the correct size studs...
someone in the trucks past has replaced the studs on the pass side and did not get the right ones...
they are correct for the SRW but duallys are shorter on the hub side and longer on the outside for the rims...
had to get out the big persuasion tool to get the spacer off..
same with the driver side..
Pass side
driver
off you go...
little scrubbing little cleaning makes it look just like new..
lithium and royal purple bearing grease..
for as small as that spring looks... its REALLY strong..
gears are in...
had to take the cap apart as it said to lube the seals... so popped the center out lubed up the seals with the lithium..
all together...
sure looks nice in there..
Sparky83
5,571
226
Norlina NC
theyre a whole lot easier to engage and disengage than the stock ones... they locked in right away... axle moved... flipped it to free... axle did not move...
I don't think I have ever used my manual locks!
Sparky83
5,571
226
Norlina NC
i have :D
