Go Back   Ford Truck Fanatics > Special Interest > Custom Fabrication
  #1
Old 03-15-2013, 05:55 PM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
Battery tray
I was changing the location of the battery on my Boston Whaler to under the center console. I couldn't find a tray that wouldn't require drilling holes in the deck , so I made one . And its stainless steel to boot. I added tie down rods and drilled one hole in the bottom of the tray in the exact location of an existing deck screw.The two tabs from the bottom slip under an existing brace and the vertical tab on the right is drilled and attached the brace.
Mark
  #2
Old 03-15-2013, 07:21 PM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
Looks great Mark
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
  #3
Old 03-15-2013, 08:18 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Slick Mark...and that SS should last a long time.
Quote:
Quote:
Quote:
  #4
Old 03-15-2013, 08:38 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Looks Great mark nice job.
Click for weather forecast
________________
Randy
  #5
Old 03-15-2013, 08:56 PM
fatherdoug's Avatar
That's beautiful!
Sea water is hard on stainless(high chlorides). But if you've got water around your battery, corrosion will be the least of your worries.
'78 F-150 Lariat
Quote:
Quote:
  #6
Old 03-16-2013, 06:48 AM
m78's Avatar
m78 m78 is offline
Thanks guys. I need to stop plying with the toys and get back on the house.
Quote:
That's beautiful!
I've taken one small wake over the bow. Put in a bilge pump the next day , even though whalers don't sink.
Mark
