Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > Electrical
  #11
Old 08-01-2015, 12:18 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
Duncan (or?), question.
Under what condition would a PWM unit operate at it's highest temperature, when the output is 100% (ie, functioning like straight through wiring) or when it's reduced to it's lowest design level?
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #12
Old 08-01-2015, 07:52 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Typically when it is reduced.
Quote:
Quote:
Quote:
  #13
Old 08-01-2015, 08:56 PM
Quote:
To the maximum that the device will reduce it to? Midway? Me asks because, I have an idea how to test and determine operating temp, and to some extent, what the upper tend temp might be.
-Bill
  #14
Old 08-01-2015, 09:43 PM
DNFXDLI's Avatar
Admin
Quote:
Typically in general...how do you like that , lowest setting should produce the most heat...but it could vary depending on the particular design...sorry I'm not more help.
  #15
Old 09-07-2015, 12:40 PM
Bench testing yesterday as proven this to be true.
Typically in general...how do you like that , lowest setting should produce the most heat...but it could vary depending on the particular design........
Again, bench testing yesterday demonstrated that the lowest fan speed (and PWM output) and 2/3 of max fan speed (and PWM output, ie, fan ~ lo lo med low) have about the same effect on heat generated by the PWM unit which is the most heat. The temp increase is also somewhat rapid under these operating conditions.
I wouldn't be so sure of that bud.
-Bill
