Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #1
Old 08-06-2016, 10:34 PM
fatherdoug's Avatar
Tips on removing a snapped bolt?
I replaced the sway bar bushings on the not ford today. There are two bolts(top and bottom) that hold the sway bar bushings onto the axle bracket. One of bolts snapped off at the head while trying to remove the bolt. I thought okay, I'll get an easy out to remove. I drilled a hole into the bolt, then inserted the easy out. The easy out snapped off while trying to turn the bolt out.
Now, I have a bolt with no head and a hardened steel easy out that won't drill out. I can't get at the backside of the bolt either.
I don't really want to drive the vehicle with only one bolt holding the sway bar bushing in place.
Any ideas?
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 08-06-2016, 10:39 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
cbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond repute
Any ideas?
Is there any way to weld a bolt back if you remove
the bushing?
If theres room to weld another bolt on ,then it may work! Ive seen it
done before!
CB
Im not a bum,Im on vacation!....
  #3
Old 08-06-2016, 10:40 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
None..that sucks.
How big was the easy out?
Can you try a reverse drill bit?...if the easy out isn't too big.
Quote:
Quote:
Quote:
  #4
Old 08-06-2016, 10:47 PM
fatherdoug's Avatar
Quote:
the bushing?
done before!
Won't that melt the bushing? I might be able to get the bottom of the bushing bracket tack welded onto the bracket, since there are two ears that slide underneath the bushing bracket.
Quote:
Originally Posted by DNFXDLI View Post
None..that sucks.
The drill bit was a 5/64" for the easy out, and the bolt is 8mm. I'm not familiar with reverse drill bits. That sounds like it might work.
'78 F-150 Lariat
  #5
Old 08-06-2016, 10:57 PM
cbaker65's Avatar
8mm is small an is the equivalent to a 5/16 isn't it?
CB
  #6
Old 08-06-2016, 11:01 PM
DNFXDLI's Avatar
Admin
Welding might work, but if it's cleaned off level it makes it difficult to avoid welding to the surrounding material...at least that is my experience.
Ask Frank to send you a can of that blue shit
  #7
Old 08-06-2016, 11:03 PM
cbaker65's Avatar
Theres blue shit?......
CB
  #8
Old 08-06-2016, 11:04 PM
DNFXDLI's Avatar
Admin
Yield...I forgot the name...like bionic weinerschliedin
  #9
Old 08-06-2016, 11:17 PM
fatherdoug's Avatar
Pretty similar, yes.
Not good. Hey, Frank, send me a can of that blue shit.
'78 F-150 Lariat
  #10
Old 08-06-2016, 11:18 PM
fatherdoug's Avatar
That made me laugh.
'78 F-150 Lariat
