Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #31
Old 04-01-2009, 10:07 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
Quote:
Originally Posted by 1985 Ford F-150 View Post
Hmm Ill need to try that one the salt got to mine in the bed toolbox I got.
That is where I learned it from. Offshore platforms, salt/air/water gets on tools and to stop them from rusting we always threw them in a bucket of diesel for a week and let them soak.
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #32
Old 04-01-2009, 10:24 PM
1985 Ford F-150's Avatar
1985 Ford F-150 1985 Ford F-150 is offline
Country Boys Can Survive
1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute
Hm does it bring em back or just eat the rust away?
Dan
72 F-250 4x4
67 CJ5
86 F-250 HD 4x4
79 Bronco
  #33
Old 04-01-2009, 10:31 PM
mrxlh's Avatar
Oilfield Trash
Nothing brings back chrome, but salt will usually keep eating at tools. The diesel will stop the reaction.
Lester
Stock
  #34
Old 04-01-2009, 10:44 PM
Ok I already pulled em out of the box and put em in the cab to keep em out of it Ill have to go get some diesel and do it. Thanks for the help.
Dan
72 F-250 4x4
67 CJ5
86 F-250 HD 4x4
79 Bronco
  #35
Old 09-19-2010, 12:47 PM
mrxlh's Avatar
Oilfield Trash
Rounded off or corrided 12 point fasteners, hammer the head of the bolt (think of mushrooming it over) pound the 12 point socket on the bolt, viola easy removal fix. First choice would be to cut the fastener off, however sometimes cutting is not a viable option.
Lester
Stock
  #36
Old 09-20-2010, 04:36 PM
UNRULEE's Avatar
UNRULEE UNRULEE is offline
^LARGE carbon footprint^
UNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond reputeUNRULEE has a reputation beyond repute
If you have a trouble some allen headed fastener and it's starting (or is) stripped out take a torx bit that is a little bit larger than the allen head and pound it into the boogered up hole. The corners of the torx will bite into the stripped out head allowing removal.
Thank God for beer and music
Quote:
Do I really need to reply to this thread? I have been fishing, drinking and then cleaning fish, followed by more drinking. Not exactly in that order.
1979 F250 4X4, far from stock
2005 F250 6.0, stock ...........I swear.
2008 Expedition Limited 4x4,Loaded, The wife's rig
2004 Lincoln Town Car, my plush work ride
  #37
Old 11-07-2010, 11:40 PM
Alvin in AZ Alvin in AZ is offline
Alvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud of
Quote:
Originally Posted by blacksnapon View Post
I'll give it a try, hang on to your worn 1/2 wrenches.
A 1/2 wrench is 12.7 mm, worn out, it will work for a 13 mm.
Cool to read that someone else has noticed that. :)
Back in the early 70's I found two different old 1/2" boxed-end wrenches that
had rusted slightly and were my main wrenches back when I was working on
air cooled VWs.
The other ends are 9/16" and aren't worth anything. :/
Always threatened to file 'em out to 15mm but just never did.
Filed out a loose a a goose shorty-boxed-end 11/16" to 18mm tho...
http://www.panix.com/~alvinj/file12/wrench18mm.jpg
Alvin in AZ
  #38
Old 11-07-2010, 11:48 PM
Tip for removing #2 phillips head screws that have a tendancy to strip out.
Take a small ammount of valve lapping compound and put it in the head of
the screw. It will make the screw driver "bit" into the screw. Also clamping
a vise grips on the shank of the screw driver and pushing down on the end
of the screw driver helps to keep them from stripping out.
x2
And what worked miracles on old motorcycles for me was to use a 3/8" starter
punch and hammer and peen the Phillips heads down to where the screwdriver
didn't fit so good, then hammer the screwdriver in for a perfect fit -then!- try
turning it.
Beats the heck out of a stripped out Allen head screw which is what I saw
other guys wrestle with, after spending money to replace all the "crappy"
Phillips head screws. ;)
Alvin in AZ
