Picturesw removed
Bob, we didn't remove any pictures. I just went and looked and the photobucket IMG codes are still all there. That means its on photobucket's end. Did you move/reorganize them in your photobucket? Something like that will have that effect...
nobodyspecial
Fire in the hole...
5,756
366
ND
Where is the thread with said pictures?
nobodyspecial
Fire in the hole...
5,756
366
ND
Yep, like was already said, if you moved the pictures or renamed the album, the links in a forum will be broken.
nobodyspecial
Fire in the hole...
5,756
366
ND
After a little investigation, I found that you keep your pictures in an album called "1978 bronco"
This album used to be inside another album called "Car Photos" which was in your base directory.
If you create a new album called "Car Photos" in your base directory (since you deleted it) and move the "1978 bronco" album back into the "Car Photos" album, all your photos in your threads will show up again. :)
