Possibly buying an '02 Taurus
TheRoadVirus
High-Steppin' Mo-Sheen
I need some opinions on what to look for, other than the common things.
This car is in pretty good shape for what it is. It does have 209,000 km, though. I need this car for 10 weeks and then it's going to be used as an extra for my parents while I'm in school.
It has the 3.0l duratec 24v v6. I'm going to assume it has a timing belt, what's the interval supposed to be on it?
Thanks in advance, guys.
nobodyspecial
Fire in the hole...
5,756
366
ND
The Taurus is a good car, my mom has one the same year. They have had no mechanical things go wrong with it, other than one time in a parking lot the shift linkage came off of the transmission, so she was stuck in park in her parking spot.
Other than that, its been flawless. Reliable, good economy and comfortable.
polarbear
just growing older not up
12,878
607
Boring, Oregon
I'm pretty sure that motor has a timing chain, not a belt.
Edit: Yep, here are the specs
VIN Code: S (More Info)
Displacement: 3.0L (182ci)
Bore: 3.50" (88.9mm)
Stroke: 3.15" (80.01mm)
Engine Type: 60° V6
Aluminum Block and Heads
Valvetrain: DOHC; 4 Valves per Cylinder; Timing Chain
Compression Ratio: 10.0:1
Interference: No
Computer: EEC-V / OBD-II
Fuel Injection: Sequential Electronic
Ignition: Electronic Coil Pack
Horsepower: 200 @ 5500 RPM
Torque: 200 lb.-ft @ 4500 RPM
