Go Back   Ford Truck Fanatics > F-Series > Generation 1
Generation 1 1948-1952 F1 thru F8
  #11
Old 09-22-2013, 07:25 PM
black_devil's Avatar
black_devil black_devil is offline
babble babble
black_devil is on a distinguished road
Going to remove the windshield and back window soon what is the best way to do so the front window is trash but the back is still good
that thing in my poket
  #12
Old 09-23-2013, 09:27 PM
mtflat mtflat is offline
Flatheads Forever
mtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond repute
The gasket is probably too brittle to remove - I just take a sharp wood chisel and lay it flat on the glass and push it around the perimeter. The windshield has four clips that fold over to hold it in place.
Front window installs/removes from the outside. Rear window installs/removes from the inside.
New gaskets are available from several vendors.
Clean and paint the body around the opening to smooth things and let the gasket slide better. Lube them really good with dish soap and use a spray water bottle as you pull on the strings - as outlined in the shop manual. Don't hurry. I broke a couple that way.
...Tim
  #13
Old 09-26-2013, 04:50 PM
babble babble
In the code I gave you earlier was wrong its actually N not M
  #14
Old 10-01-2013, 03:57 PM
babble babble
Got a little done. The windshield came out thanks to the help and advise plus I got the dash cluster off eBay and got it apart and painted to match the future colors of the truck. I like it just got to get the putter trim piece fixed and its done.
  #15
Old 10-01-2013, 09:22 PM
Flatheads Forever
That sounds better - I have a note that the chassis manual for '52 lists Vermillion Red as code N.
...Tim
  #16
Old 10-02-2013, 08:08 AM
babble babble
That's going to be hard to find
droid jkf2 1950
  #17
Old 10-02-2013, 03:10 PM
slmann's Avatar
slmann slmann is offline
slmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond reputeslmann has a reputation beyond repute
looks like a cool project.
2010 F-150 STX 4X4
  #18
Old 10-20-2013, 06:33 PM
babble babble
I'm taking a break on the truck for a few days. Soo much still to do but one thing at a time is the only way to go
droid jkf2 1950
  #19
Old 10-20-2013, 07:50 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
It does! .
  #20
Old 10-20-2013, 08:32 PM
babble babble
droid jkf2 1950
