4498 -2011-2012 F-super Duty - Traction Control Light On - Dtcs: C1b00:29,41,62,63,64,86 - Service Tip
Some 2011-2012 F-super Duty Vehicles May Exhibit A Concern Of Traction Control Indicator Illuminated In Instrument Cluster With Diagnostic Trouble Codes (dtcs):c1b00, C1b00:29, 41,62,63,64,86 In The Antilock Brake Module(abs) For Steering Angle Sensor(sas). Check Tire Sizes, Pressures, And Circumference And Adjust As Necessary Prior To Following Wsm Diagnostic Procedures. Refer To The Door Placard For Tire Size And Inflation Information. Differences In Tire Circumference Can Lead To Differences In The Wheel Speed Sensor Values That Are Used As Inputs/checks On The Sas Signal. If The Information From The Wheel Speedsensors Do Not Agree With The Sas Signal, The Code(s) Are Set And The Traction Control Indicator Is Illuminated.
