2007 Superduty 4WD front hub fluid change
my bad its called the 4wd front axle and it takes 2.9 quarts of 80w-90 syth. I used the grey gasket maker(the one in the cheese can)....the fluid should come up just about level with the fill hole. I just snugged everything up and used red thread lock cause I could not find the torq. Grey gasket dries quickly and the vehicle can be driven right away. I cleaned up the cover and painted it with a quick coat of gloss black. It's not a hard job once you get the cover off.
*just dont jam a screwdriver in it trying to pry the cover off and scratch the mating surface.
You've pretty much got it. Answered your own question before I could get on!
