Cantankerous The PowerStroke Rebuild.
masakimm
Native Texan
158
1
Ok back at it again. So My truck is still young. But decides she need some tlc.
So 349000 miles still had the original Hpop and Injectors.
So it was time to yank the motor out for some love.
yeah the rear main needs some loving it was leaking and a mess.
Started tearing into the motor Wjat was suprising was how clean the inside of the motor was Could still see the cross hatches in the cylinder walls. The markings from assembly were all still there. Sorry the heads pics got corrupted when my hard drive crashed.
So installed new pan and rear main onto the motor. looks much better now.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
heavydoc
Instigator
70
WNC
Dam I was just bringing up this thread to ask about some updates[emoji1787][emoji1787]
masakimm
Native Texan
158
1
So yanked all the injectors out and took pics cause they had 349000 miles on them they ran great just a little cold start and cold running issues.
So from the look of these they would have need to be reringed but other then that I think they were fine.
So I had many choices of injectors(way to many) I actually had spent months reading and reading and reading. But I finally decided on my injectors.
So I bought a set from Unlimited Diesel Performance They had good reviews and the warranty was great. So got a set of 160/stock nozzle Stage 1 injectors. Also the price was good to. They came in well packaged and have been really good so far.
masakimm
Native Texan
158
1
So on the Hpop system. Of course I resealed the end rail plugs.
So I went thru the whole research process again and had it narrowed down to 2 Hpop's. I choose the Dynoproven Baby Badger pump. It ended up coming down to price at the time. The badger was couple hundred cheaper at the time then choice 2. Well shortly after my purchase they went under(Of course they did).
Well one day I came out of Lowe's and saw a puddle under my truck. Climbed up on core support and started looking for the problem and found this.
So pulled the pump out. and inspected it not very happy at this point. The company was gone so no support or warranty. At this point it had less then 5000 miles one it.
So I read u can press the pump back in with a large Clamp but after cranking on it as hard as I can it would not budge. So now what to do.
masakimm
Native Texan
158
1
So decide it was time for option 2 that I had not choose because I wanted to save 200 dollars. Well that worked well didn't it. So called up option 2 And discussed my problem. And to my surprise they agreed to take my Badger pump as a core.
So Called Dieselsite up and ordered my Adrenaline Hpop. They got it out to me fast. Which was good I need my truck.
Well of course I pit the badger in a vise to remove the IPR valve and as soon as it broke loose the pump came loose from the vise and hit the floor bending my valve. This sucked since it was a new valve with less the 5000 mile on it. but I had my old valve as a back up so used the new coil on my old valve. And got her installed. And fired her back up. Then......
Well that's not good did I blow a line did I blow the Hpop up. Why is my oil on the floor.
Well this is why all my oil was on the floor.
So called Dieselsite up and told them what happened and they were very helpful and got me a replacement sent out that same day. Apparently some of the bores get worn and won't hold the sealing ball in under heavy pressure.
So since I had the time I went ahead and ordered a replacement IPR just cause I still have the old one with the new coil as a spare along with a new spare. So got the new pump in and installed and fired her up and she runs great. So ends my Hpop drama hopefully so saving 200 may not pay off in the long run. It didn't for me at least.
masakimm
Native Texan
158
1
Wait don't u have something to shoot. Ill get this updated some day.[emoji1787][emoji1787]
heavydoc
Instigator
70
WNC
[emoji1787][emoji1787] I dooooo, and waiting my turn is is just pure torture. My time slot ain't till 2[emoji36]
masakimm
Native Texan
158
1
So now fuel.
Don't know why these ended up in the fuel system but I did upgrade the IPR wiring.
So what to do with this I had put a life time warranty carter pump on but just didn't want to mess with it anymore.
So time for some new stainless steel lines for my efuel setup. Installed new regualator and plumbed it in to the front of the heads. And plumbed new fittings and line to the rear of the heads. The ran new lines from up top and used the original ends to allow me to couple into the original fuel lines from the back.
Installed a pressure gauge and set my fuel pressure to 63 psi.
And then my gauge sprung a leak so had to remove it for now. So this was the simple part of the fuel system. And came out very well and has served me well for 5000 miles. Except for the pressure gauge.[emoji1787]
masakimm
Native Texan
158
1
So couldn't do all this with out addressing the turbo. If anything was done to it it was done by Ford before 92000 miles. As that's when my shop took over all the maintenance from Ford.
So removed the butterfly and plugged the shaft hole as I didn't want to buy the delete version.
So yanked it all apart and cleaned it all up. Ordered a 360 bearing kit. And A delete pedestals.
So all reassembled ready for reinstall.
masakimm
Native Texan
158
1
So next up was some exhaust work. I had previously upgraded the down pipe and exhaust.
So noticed the exhaust manifolds looked to be leaking. So pulled them off to have them plained.
All cleaned up ready to reinstall.
Got a set of new bolts for the manifolds.
All bolted up sealing up nicely again. No gaskets just pure metal on metal sealing as they were meant to be.
What u think I was going put those old nasty uppipes back on. Got this set from DieselOrings. Bolted up nicely and are very good quality just not nice on the pocket book.
So Like was said exhaust was upgraded before the big upgrade. So its not shiny anymore. Came with a 3 inch down pipe and 4 inch exhaust with muffler. It originally went over the rear axle and out the passenger side. But with the new rear fuel tank that's was not possible anymore with out a custom tail pipe so I choose to dump the exhaust down in front of the axle. The first attempt was not a success as it cooked my swaybar bushing so added an extension to dump it straight down on the ground and has worked great for now.
masakimm
Native Texan
158
1
Started a new project on my Truck. Here's a sneak peak.
You going to haul it to the truck emergency room????
[emoji6][emoji12][emoji81][emoji81][emoji81]
masakimm
Native Texan
158
1
nope but part off of that will be going on my truck.
Are you going to have to use the emergency brake driveshaft drum for your truck?
masakimm
Native Texan
158
1
no but I might use it to buy some freedom on a particular site.[emoji1787]
LOL, that may halfway help.
you still have your daddy on the other half.
:rolling laugh:
