Old 03-01-2019, 01:09 PM
rjphillips's Avatar
rjphillips rjphillips is offline
mudman
rjphillips will become famous soon enough
Highboy front u bolt torque specs??
Was wondering if the front u bolt specs are different than the back on my early 77 F250, with a 3" front spring and 9/16's u bolts.
I come up with 110-130 ft lbs for the rear only, wasn't sure if the front were the same, just didn't want to over torque them and break an ear off the cast bottom plates, have them @90 ft lbs right now and they seem to almost be stretching if I try to go up to 100 ft lbs. Yes they are new u bolts.
Hope someone has a better idea than I do.
Thanks.
Mudman.
Early 77 F250 Highboy
400 C6
33" SSR swamper radials on MT classic III
Old 03-02-2019, 12:50 AM
fatherdoug's Avatar
http://www.fordtruckfanatics.com/for...ad.php?t=29243
Granted, this is for a '78 F250, but the spec for 9/16 U-bolt spring to axle is also 85- 115 ft/lbs. Look at page 14-31-12.
'78 F-150 Lariat
Old 03-02-2019, 02:47 PM
rjphillips's Avatar
mudman
Thanks fatherdoug, appreciate the help, at least I was in the ball park.
Think I'll leave it at 90 for now, drive it a bit then retorque and see how it ends up.
Mudman.
400 C6
