My project truck 1978 f250 4x4 400 4 speed
Thought I would start out with a big hello to my fellow Ford fans. I picked up a 1978 f250 a month ago and have started a rebuild process with my son's help.
Hopefully I can capture some of it here. Not sure if the pick will post but here is my truck.
CYkv21OJCxAQsop-YMvgKENBSYMhdb6zXb4JqKefdYOJ4BHUXNjp-Ya4Q7vVv8mwibO3hOkR2JREt1FxuwFrcWTQrFJ0Uo2q8aqP9-Nm7jZDZjUvZKxiHrhM1Z6c43yp_0svdHOjPQNdGDhS68M_cHOobutG9ZkNmz9o9N12kTeJwYI3b8mHOJUjZoZPuPn41py5zvDvVNg7pPnOipl5OZc7OJN3wsNDPQOknjB93A7AoqomeAQ_4st35Vb_TF_5IBsgTWoQDRPM1SK2SPGPp0GQ3GZelNUVZJUDqOFLFXEcWDqxPtY0iT7MCnZeccSaQm-Bicx2I0rnvkV-DJF_gnNkGi-nlxR58qYurN6zAvEvpSVV7HBBKeOeRuhGGGkgBH4yqjfW6taE-doCCgRE7LeL1KrdCAijU5O5J0birtTRaGvmkUVaylIOBsdGBFvn4CED6MOTYzXXwBZuxdlr2A8xZqiWbqIL1R-mQeyU9fjpZJJofR5_lQXXL5GyZg6C80AXTCJC85eV9PuG56L8Q3IARC1E_rZLgOiI8JeSWEvz=w1200-h676-no
Sent from my Nexus 7 using Tapatalk
Didn't post....sounds like a cool project, looking forward to seeing your progress...and the truck!
Sent from my Nexus 7 using Tapatalk[/QUOTE]
Hopefully this one works
Are you using a 3rd party pic host or uploading here?
Progress to date
Well been a long couple weeks. Here is what has been done so far:
1. Replace original ford hubs with Warn Premium hubs, can't get the drivers side off, seems like something is bound up or the outer shaft is damaged.
2. Replace everything on the front of the engine, timing chain edelbrock 4 degrees advanced, water pump, fuel pump, thermostat, heater lines, sleeved harmonic balancer, and a new front seal.
3. I am cleaning up the radiator now and will be de-greasing the rest of the engine bay trans, etc. Put in a new coolant reservoir, washer pump reservoir and pump this weekend. Hopefully now we have more oil in the engine then out of the engine.
Next big project will be the wiring harness. The glove box light looks like it shorted some time ago and burned its way back to the fuse box. This resulted in a melted pool of sheathing and a lot of wires that should have been shorted. I have a new harness coming. I will post how that goes after I get it here.
And This to
Found this while digging around as well
Rear leaf rear hanger bolt backed out sometime in the last 30 years, hopefully in the short term I can tighten up, can't find a reference to what size bolt it is.
Using Picasa. I think it should be working now. I didn't have the pictures in a public library. let me know if it doesn't work and I will adapt.
Thanks,
It worked, if you choose to use the galley here, the pics can be much larger and easier to see, but whatever works for you smilieFordlogo
Big Jim F150
73-79 Ford Trucks Rock
Awesome truck!!! Welcome to the ol FTF! Good choice is the 6th Generation trucks, especially the standard cab long beds. I have a 78 F-150 Ranger Lariat Trailer Special, that's also a standard cab long bed but mine is a two wheel drive with a 400 engine with an Edelbock intake manifold, with a Holley single feed four barrel carburetor, and a GM style HEI distributor, and ACCEL 8MM plug wires with a C6 automatic transmission with a shift kit in it. Which a great combination , and I'm very happy with it. Dents or Dentsides are slang names for the 73 - 79 body style due to the upper body contours. Have fun, take your time, and PLEASE don't give up, be be patient for you'll have a good looking truck, although you're starting with a good solid truck for your project.smiliegitrdonesmilieFordlogo
Well had a fun week. Had to tear it back down to the timing set to fix a engine problem and repair a stripped water pump bolt. Used a halicoil for that, pretty slick tool. Turns out I may have an aftermarket cam. When I set my crank sprocket timing set to 4 advanced I was getting severe blow back as I revved the engine. Set it to 0 and she runs awesome. Starts with a bump revs fast and strong. Vacuum jumped from 10 to 18 inhg.
Spent a few hours degreasing the engine bay, transmission, transfer case etc. I can see grease zerts, case stamps, all kinds of interesting things that were buried under years of grease. Hopefully i can find where else I am leaking and start the process of fixing them.
Got the new wiring harness in, may try to hunt with the truck before I put that in place, looks like it is going to take some time, but should be pretty nice and solve some other miscellaneous problems with lights and other items. I will probably do a how to on that one as I do it.
Good luck to all of you working on your trucks.
keep it up. happy thoughts of cleaner components, i had rolling under grease ball trucks and equipment.
