10.80 1/4 mile 79 Bronco
countryboytn
'78 Bronco owner
http://www.dragtimes.com/Ford-Bronco-Timeslip-16129.html
Engine: 950+ HP Siamese bore 4 bolt main A-460 Big Block Ford 598 C.I
Drivetrain: Hughes Performance C-6 with wide ratio gear kit 2.72 first 1.54 second, Hipster transbrake, 9 inch 5200 stall converter, Chrome Moly 4 linked Ford 9 inch with Strange Pro Iron case Strange 4.71 35 spline Pro gears Mark Williams 40 Spline axels and spool, Weld Draglite Wheels and Hoosier 32.5X 14.00 slicks
blackhat620
You Had to be There
1,687
150
Arizona
He did a nice build, spent some serious coin along the way.
Jon Kasse builds some nice race engines. The one in that Bronco starts at $25k and goes up depending on configuration.
www.jonkaaseracingengines.com/products/engines/600-ford/70-600-ford.html
countryboytn
'78 Bronco owner
Something about seeing a vehicle as big as a Bronco pick the front wheels off the ground makes me go :drop:
And yeah, he definitely has a fortune tied up in that thing!
he can do this ----> :bowdown:
