- 31
- 0
Hello,
I'm hooking up an ignition switched continuous duty solenoid in my '92 F250 LB, Reg. Cab, a/t, 4X4. This is to charge the aux battery in my slide-in camper while not discharging the truck battery.
Where is the "easiest", under hood, tie-in to the ignition? (The "easiest" that will do the job safely and effectively.) What is the color code for that tie-in if it's a wire splice?
Thank you.
Thank you.
