auto to manual choke.
Tyler in all seriousness...you may want to consider pump replacement and call it a day...The bolts location is very close to the water jacket of the pump and is going to require a Center punch,variable speed drill..some good quality carbon tip drill bits...extraction bits and a 3/8 course threaded tap along with disassembly of the fan & shroud, top pulley maybe even the radiator....grant it it would be a good one to learn from..but be ready for plan B for if you make a mistake it will not only cost you the pump..but the core as well.
Craigslist is crawling with ford parts right now. All the body parts I need a bunch of 390's a couple sets of turbine rims and stuff. There's several 4bbl intakes
