Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > Alternative Fuels
Old 10-19-2015, 06:36 PM
ALAN's Avatar
ALAN ALAN is offline
ALAN is on a distinguished road
Fuel mileage E85
I have a 2008 f 150 just got not to long ago it is a flex fuel. ..Can someone tell me what mileage I can get with it compared to regular...I have 5.4 window sticker says 19 highway 13 in town..Am I gonna get better or worse with E 85
Old 10-19-2015, 07:11 PM
Lost's Avatar
Lost Lost is offline
Lost is a glorious beacon of lightLost is a glorious beacon of lightLost is a glorious beacon of lightLost is a glorious beacon of lightLost is a glorious beacon of light
Worse All our company cars lost about 2MPG
If you can't find a part used u r not looking hard enough..
94 F150 302 MAf E4od sc long bed 4x4 3:55 LS rears
9MM Ford racing wires MSD cap & rotor and Blaster coil coil . 14-15 MPG Thanks
95 F150 300-6 auto 4x4 8 ft bed barney mobile (yep its purple) . 1 ton front coil and f260 rear leaf suspension Its the plow/firewood truck
Old 10-19-2015, 08:11 PM
CowboyBilly9Mile's Avatar
By volume, alcohol contains 2/3 the energy that pure, 100% gasoline does. So let that be your guide as you crank out a comparison between E0 and E85.
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
  #4
Old 10-19-2015, 09:42 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
The engine is designed for running regular gasoline. As such, it does not get as good of mileage from it. In order to do well with the E85, you would need higher compression than what gasoline allows. This dual fuel garbage doesn't work with propane, nor does it work with E85. The properties just don't trade off well, and mileage will suffer.
My trucks:
  #5
Old 10-20-2015, 12:32 AM
polarbear's Avatar
polarbear polarbear is offline
just growing older not up
polarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond repute
The only real advantage the flex fuel setups have, as I understand it, are fittings and fuel lines designed to tolerate the corrosive qualities of E85 fuel. We don't have this choice in Oregon- everything's E85.
"Hillbilly Deluxe"
  #6
Old 10-20-2015, 02:58 AM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
I'm an self confessed alternative fuel freak who has messed around with diy hydrogen hybrid system's and am currently experimenting with ethanol in my spare time ..... i'm pretty hung up on the advantages of ethanol especially as originally promoted by Henry Ford's Model farm distilleries.
The trouble with that energy calculation Bill is that it is based on a BTU measurement ..... BTU stands for British Thermal Unit and is a measure of heat energy not Combustible energy - eg a stick of dynamite only has 2000 btu whereas a gal of gasoline has 125000 btu . Even though the dynamite has only 2000 btu it has an explosive energy many times greater than the gallon of gas..... It's all in the way you harness the available energy that counts towards the final result
I couldn't agree more Roger - Gas has a stoichiometric requirement of 14.7:1 whereas ethanol has a requirement of around 9:1 with a fluctuating requirement in between those figures depending on percentage of gas in the ethanol. With Flex Fuel systems there is basically two maps in the ecu that change (advance) the timing and increase the fuel flow (pressure or volume) if E85 is detected in the system (the really clever systems can work with any percentage up to E100 although this is mostly done in Brazil). Gasoline typically burns in an engine at around 25 - 28% efficiency - if you try to increase the compression ratio to get better efficiency you'll develop pinging and knocking. Ethanol however can get up to 38% efficiency as the compression ratio can and has been raised up to 17:1 before pinging occurred .... of course spark ignition is no longer used at those levels. Just from anecdotal evidence I've read and people I've talked to 11.5:1 seems to be the minimum compression ratio that you want to build an ethanol to so as to achieve the same or better efficiency as a modern gas engine. There are currently engines under development that are aiming for a variable compression ratio and if they ever get off the ground then pairing those up with a flex fuel system will give you the best of both worlds imo.
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
  #7
Old 10-20-2015, 06:04 AM
fatherdoug's Avatar
Good read, Mark. Thank you. How does the ECU determine what type of fuel is being fed to the engine?
'78 F-150 Lariat
  #8
Old 10-20-2015, 06:41 AM
Fellro's Avatar
Admin
There is a sensor in the fuel line that detects the level of alcohol in the fuel. I know there is always chatter about the corrosiveness of E85, but I have run E10 all of my driving life and have yet to see it. The tank on my 83 Trans Am is as clean on the inside as the day it was made, and I have run E85 through it as well. I also haven't seen any unusual deterioration of the fuel lines and seals, even on a car that had gone 5000 miles shy of 400,000 miles running exclusively E10 and occasionally some E85. I changed the injectors at 250,000 miles as they were simply worn out.
My trucks:
  #9
Old 10-20-2015, 05:31 PM
fatherdoug's Avatar
Thank you. Is the alcohol detected by difference in density? Enquiring minds want to know.
'78 F-150 Lariat
  #10
Old 10-20-2015, 09:06 AM
ALAN's Avatar
Thanks for clearing that up...reason I asked a guy brought a 2010 mixed e 85 with regular gas which was at half tank and he tryed telling me he got 22 mpg....Mine is flex fuel also so before I added e85 wanted to see what milage would be...I'm sticking with regular..
