I recently purchased a brand new rear slider window for my 74 ranger xlt i would like to know how hard will it be to take the solid window out and put in the slider? also what tools would i need?
Start inside at the top of the "gasket" at one corner. Pushing out slightly, use a flat implement (I just use screwdrivers) to curl the gasket over the pinch weld. Work your way around.
Yeah it easy,even easier to put back in. Wrap a chord around the gasket and position the windowface. Have a helper hold it, pull the chord and it will pop the seal in place.
They can be a pina even when you know what your doing. The old seal might have to be cut to get it out. I suggest searching youtube to see if any body has posted a video on it.
They generally aren't bad, but as mentioned, if by chance the seal is hard, could be a bit of a trick. I haven't generally had a problem, even with trucks that have sat around for many years.
It's true that the window was the same from 73-95, but I belive the older windows had thicker glass than the new ones. I've heard that if you're putting a newer window in an old truck to make sure that you order the correct gasket for the year of the WINDOW not the year of the truck, so that it will seal properly.
