351/400 Fuel Line Help
Does anyone know if a Fuel Line for a 351 2Barrel Fit on a 400 2 Barrel?
My fuel line's totally shot.Found a replacement for a 351 & it looks very close.
Any ideas,suggestions would be appreciated
I would imagine they would, they are the same block.
The fuel line from the fuel pump to the carburetor is the same. There is a difference in the position of the output of the pump, based on whether or not the vehicle is 4WD or 2WD. On one(I don't remember which is which), the ouput line of the pump faces toward the fender, on the other, the output line faces toward the front of the vehicle.
If you're talking about the line from the fuel pump to the tank, then the only difference will be whether or not the truck is a shortbed or longbed.
I didn't know that, thanks Doug.
