Brake light and reverse light wiring problem
well a few days ago i posted about having no reverse lights on the 88. well now it has only 1 brake light again.. this had happened a few months ago so i replaced all the bulbs. well now it has happened again.. i havent got the chance to really pull it apart and check anything but i got a circuit tester to check if im getting power to the connectors in the socket. if i am then i know its a bulb connection problem... but the only problem with that is the parking lights work.... but if not that means a short circuit somewhere or ground problem. cause all the fuses are fine. but first off what should i hook the aligator clip on the circuit tester too? aint it gonna be a ground? but any more tips?
here is the wiring diagram and i dont understand any of it....
not real good with electrical...
Fordzilla80
Ranger Lariat
6,372
262
Narnia
All the circles with squiggly lines are bulbs.Blk is usually ground,and dots at the T's(where one wire meets another) are splices.
Wht=White
LT Blu=Light Blue
Those abbreviations indicate wire colors.Just follow the wires.
Keep in mind the wires could be completely different colors than what the diagram lists.One thing I can say is that the license plate lights use a brown and black wire,it's that way on my 80,and it's that way on a buddy's 95,I don't think they changed those colors.
A_G
wuh?
3,188
74
Tulsa, Ok
yep looks like your looking for a Black and apink wire going to your rear back up lamps, and a black wire ground, So check the ground.
and ont he brake lights
Light green and a orange, going into the lamp and black gorund, with brown running out .
the righ tone is, light blue and orange.
Good luck, Have fun
ok ive got the tail lamps apart and i was looking for a ground spot and i cant find any ground spot. i have the brake lights fixed but it still has no reverse lights. where would the ground be for the reverse lights.. and if it has a good ground where is the reverse switch?
