'89 F-150 tilt column Key housing gears
Having read what I find here on this, i'm still looking for info.
Made a huge mistake removing the collar that holds the Key housing, now am struggling to get the gears lined up right so that the key will move into all positions. It's the gears on the 'tilting' L-shaped slide and the round gear at the end of the key lock housing that I still haven't found the right technique to put back together in the proper orientation.
Hopefully others have licked this problem and remember how to line this up properly.
Thanks for your help, i'm hours into this without solution.
