Gas tanks
My 19 gallon tank is shot in my 78 1/2 Ton I was wondering will the 38 gal tank fit up in my frame I can see they are taller but what the length/width
Sent from my SM-N920V using Tapatalk
heavydoc
Instigator
70
WNC
Is this a rear mounted tank in-between the frame rails? If so yes, it will be tight and you will need new or fab some mounting brackets and make a deeper fuel pick up tube
Bronco tanc works, but the frames are different. You have to make your own lower straps, and use the hanging unit for inside the bronco tank.
The fuel sender is wired different, and requires the bronco end to the tank. Junk yard can provide that.
Bronco tank in a pickup
