darn... was my only guess after the others suggestions...
Dec 19, 2014 #41 Sparky83Virginia Chapter member5,571226 Norlina NC darn... was my only guess after the others suggestions...
Dec 19, 2014 #42 84-6.9LUnder Funded150 Are you sure you have your advance hooked up to the right port on the carb? It sounds like its hooked to manifold vacuum instead of the "timed" vacuum. There should be no vac to the distributor at idle.
