Air intake restrictor on a 97 460?
460Trucker
Has the Cat Scratch Fever
Hello everyone!
I've been doing some reading on increasing power output from a 460 and came across some information that suggested removing a restrictor in the air intake system to assist with power gains.
Would this benefit with a higher volume of air flow? Also, how do you go about removing it? I'm in need of a winter project while its in storage smilieFordlogo
460Trucker
Is it only for stock intakes? I have a K&N aircharger that I replaced the stock one with that made a noticeable difference.
Beach66Bum
Top Poster Of Month
The kit retains (or if you like to replace) the stock air filter. The kit just changes the restrictive air horn to a larger more free flowing design. I too have replaced the factory filter with a K&N drop in filter. Getting the clean air from outside the engine compartment is the key. A lot of those kits that replace the stock system entirely may actually decrease performance!
460Trucker
Gotcha. I've heard about the decrease in performance on carb engines, I'm guessing that would apply somewhat to EFI's too.
460Trucker
Well pulled off the air intake hoses to find that someone has already cut off the restrictors. Talk about an easy project!
