- Moderator
- #1
I use battery tenders on everything I own, the 350 being no exception, especially being that it might sit for a week or two without being driven.
I've just popped the hood and put the alligator clips on the battery and gently put the hood down...I did try using the adapter that they give you with the Tender, but it was too short and I've not had time to extend it.
I did that today...extended the cable and mounted the socket to the tow hook with some tie wraps.
Getting a rough cable length
Original with the clips
Snipped off
Extended and ready to install
Everything loomed and tie wrapped
Ran it down in front of the rad support and out the frame rail
Much easier...
Snipped off
Much easier...
