Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Ranger/Bronco II
Ranger/Bronco II Mazda B-Series
  #11
Old 08-04-2017, 09:58 AM
dustybumpers's Avatar
Unless you buy the adapter, that previous post is the solution
Charlie
  #12
Old 08-04-2017, 11:59 AM
john112deere's Avatar
john112deere john112deere is offline
Super Moderator
john112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond repute
^^There's an adapter? Where do I find one/what are they called?
It was easy to find an adapter box to add a 4-way flat trailer plug (with combined stop/turn bulbs) to my '97 Ranger (with the separate, amber blinkers) but I'm not having luck finding the right search terms for one to go this way?
-Ian
1997 Ranger XLT 4x2, 2.3L 4-cyl 5-speed -- 2009 Ranger XLT 4x4, 4.0L V-6 5-speed -- 1986 BMW R80
The advantages of modern engineering are in many ways over balanced by the disadvantages of modern civilization.
--Col. W.A. Roebling
  #13
Old 08-04-2017, 01:31 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
There's no easy way that I know of... went through that on a headache rack recently
-Frank
Quote:
What's your view on sheep?
  #14
Old 08-04-2017, 01:43 PM
Super Moderator
An internet search turned up a suggestion that there's a capped green wire "somewhere under the fuse box" that does what I need...but I didn't see it at a quick look. Plan "B" might be to try to find the wire that runs to the third brake light above the rear window and tap into that.
I'm also toying with the idea of getting the middle piece of a set of rear clearance lights (the one with three red lights on a bar about 15" wide) and wiring it up with the outside lights on their respective taillights, and the middle one on both taillights...which should give me "high-mount blinkers" and a three-piece stop lamp. A little worried it'll just look stupid, but it'd be pretty easy.
-Ian
  #15
Old 08-04-2017, 01:59 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
Quote:
Originally Posted by john112deere View Post
...this truck just has red stop/turn lamps on the rear...which means if I tap into the "brake light" it'll blink with one of the directionals. Which I won't tolerate.
So...there's got to be a solution to this....but I'm not familiar with what it is?
This has come up a handful of times on the other truck forum I frequent and I think the answer is still to buy "the box". Could always do a search over there, wasn't too many weeks ago the subject came up (again).
Edit: Tap into the wire running to the 3rd brake light. The harness is inside the vehicle, among locations it will run on the left side of the center hump, if like mine you could tap into it in the back but there are several great places. Pull the left seat, remove the carpet to body trim along the lower door opening, lift carpet and do what comes naturally.
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #16
Old 08-04-2017, 02:24 PM
You should be able to pull the 3rd brk light on the truck, and tie into that wire.
Drop it back into the cab, and "sneak" it into the interior. Go dow to the rubber plug above the body mount, and poke a hole, stick the wire through, then down the frame you go
Charlie
  #17
Old 08-23-2017, 04:44 PM
Super Moderator
I didn't really want to run a wire all the way from the cab, but finding the "logic box" was proving damn near impossible...until I had a brainstorm.
WalMart sells a geezer-style receiver hitch cover that's an "extra" taillight. Comes with a logic box- for $13. I'll toss the light assembly. Seeing as I don't have a trailer, I may just leave it set up to plug into my four-way flat connector for now...it's cheating, but 100% reversible if I ever want to do it right later on.
*It took me a minute to understand how the thing worked, but I did finally figure it out. Long story short it'll light up only when it sees something from both sides...so the CHMSL will flash with the four-ways, but that's OK- just as long as it doesn't go with the directionals I'm happy.
-Ian
  #18
Old 08-25-2017, 09:19 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
That's a sweet short cut, nice find.
  #19
Old 08-25-2017, 09:47 AM
X2, good job on repurposing an easy to find item!
-Bill
