Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #341
Old 08-19-2017, 10:54 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
The compressor has a spined shaft as does the engine drive....there is a splined coupler that joins the two...of course once it is moved they don't line up...it was ghey.
Quote:
Quote:
Quote:
  #342
Old 08-20-2017, 04:47 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
Oooh, it's a Silver 92..... I don't know if you know how to feel about that Duncan, but I do!!!!
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #343
Old 10-14-2017, 09:23 PM
DNFXDLI's Avatar
Admin
It moves it along nicely....according to the shop manual it is 475/1425 in an RV application.
  #344
Old 10-15-2017, 04:09 PM
fatherdoug's Avatar
Looks like a beast!
'78 F-150 Lariat
Quote:
Quote:
  #345
Old 10-16-2017, 06:39 PM
dustybumpers's Avatar
It can be turned up........
Easy to do. They scream then......
Charlie
  #346
Old 10-16-2017, 07:02 PM
john112deere's Avatar
john112deere john112deere is offline
Super Moderator
john112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond repute
Bet it does move along nicely...my big work truck doesn't turn out numbers near that good, and I suspect it's a fair bit heavier, too. It's also a thirsty dog of a truck, so perhaps not a great benchmark.
-Ian
1997 Ranger XLT 4x2, 2.3L 4-cyl 5-speed -- 2009 Ranger XLT 4x4, 4.0L V-6 5-speed -- 1986 BMW R80
The advantages of modern engineering are in many ways over balanced by the disadvantages of modern civilization.
--Col. W.A. Roebling
  #347
Old 10-17-2017, 07:30 PM
DNFXDLI's Avatar
Admin
Not easy Charlie....ddec1...if it was a 2 or better then easier, but 500/1450 is about it without running into heat problems.
Quote:
Weighs about 46000lbs loaded...50000lbs with trailer.
Got about 5mpg USA doing 68mph
  #348
Old 10-17-2017, 08:04 PM
Super Moderator
OK, so about the same weight. I was guessing yours was 10k lighter.
But I'm only about 385/880, I think. Overall average is 3.2 mpg but we idle a lot- I can do better than 4 over the road. Although probably not at 68 mph.
-Ian
  #349
Old 10-19-2017, 12:39 PM
DNFXDLI's Avatar
Admin
When I brought it back from Northern BC, I got about 6mpg...that would have been empty except for fuel and half propane.
I'd have to check but I think we were about 42000lbs.
This last trip we ran the genny a good amount as well....the 14 hour drive up there we had 4 a/c units cycling.
They are all steel Ian...actually rollover rated.
  #350
Old 05-26-2018, 07:55 PM
DNFXDLI's Avatar
Admin
So after a couple of trips a few things have been noticed.
Coolers full of ice are heavy and a pita.
Also each of us has a tote for our gear.
There is lots of room underneath but it's surprising how much gets eaten up by 3 coolers and 3 totes.
So.....putting a beer fridge in that will run off the inverter. Also decided to say to hell with the solar.
The reality is that where I go it doesn't matter if the genny is running so I will just fire it up when we leave for the day and let it charge the batteries and run the fridge.
Batteries are being upgraded to 4 L16 Matrix AGM....440 a/hr.....at 80% DOD they will do about 700 cycles....I might draw them down that much 10 times per year...so longevity won't be an issue.
Fridge will hold 65+ cans.
