Go Back   Ford Truck Fanatics > General > Hobbies
Hobbies For non-truck related hobbies
  #1
Old 06-26-2016, 02:54 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
Electronics question - variable resistors/pots
Same general question, two different scenarios.
a) trim pot used to adjust voltage to the base of a transistor......the center/variable end goes to the base, one end on the carbon band (for lack of better desc) goes to the supply voltage and the other goes to ground.
Q. Why the ground connection? Stability? To establish a possibly used maximum resistance between the supply voltage which may keep some component of the supply, such as an IC, active?
b) trim pot in series used to adjust voltage, the center/variable is tied to one end of the carbon band and together these form one connection; the other connection is the other end of the carbon band.
Q. Why is one end of the carbon band tied to the center/variable connection and together they form one connection? Again, stability?
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #2
Old 06-26-2016, 06:51 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
If the pot ends are tied to the supply and ground, it forms a voltage divider...if you are only using 2 pins you wind up controlling current...like a rheostat.
On the connection to ground, you are using that as the reference..and there will always be a current flow from the two fixed ends of the pot.
Quote:
Quote:
Quote:
  #3
Old 06-26-2016, 07:21 PM
Quote:
Makes perfect sense.
Is this the ans to Q #2?
That's along the lines of what I was thinking.
-Bill
  #4
Old 06-26-2016, 07:29 PM
DNFXDLI's Avatar
Admin
Yes regarding question 2.
Also, I'm assuming you are using linear devices...Logs or reverse Logs or whatever the hell else they are making now would be entertaining to say the least
  #5
Old 06-26-2016, 07:40 PM
Ok, so on the 3-pin pot, two pins become one as descriobed, and the device now functions with those two now counting as one, and then the one other pin, and regulates current. Right?
-Bill
  #6
Old 06-26-2016, 07:58 PM
DNFXDLI's Avatar
Admin
Yes.
  #7
Old 06-26-2016, 08:03 PM
Excellent, thank you for answering the Q's it's always most appreciated!
-Bill
  #8
Old 06-26-2016, 08:04 PM
DNFXDLI's Avatar
Admin
Anytime Bill...just remember that I have not farted around with this stuff for 30+ years.
  #9
Old 07-24-2016, 06:47 PM
Well darn, smoked my only 10K pot.
Edit: Stunk worse than the fried IC to boot.
-Bill
  #10
Old 07-24-2016, 07:12 PM
DNFXDLI's Avatar
Admin
So it did limit the current once it released the magic smoke
