Go Back   Ford Truck Fanatics > Engines > V6/I6 Ford Gasoline Engines
  #21
Old 10-21-2011, 08:43 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
Looking good!
  #22
Old 10-23-2011, 11:06 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Ranger Lariat
Fordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond repute
Thanks Ryan!
Shaun
1980 Ford F150 Ranger Lariat
2003 Ford Ranger Edge
  #23
Old 12-10-2011, 12:24 AM
Ranger Lariat
Well it turns out that my 300 has had some work done to it in the past. I took a closer look at the rod bearings as well as the main bearing caps, and they were both .010 oversize. The rod bearings were Clevites while the Main bearings were Federal Mogul. I didn't even bother trying to get the cam bearings out, and I wouldn't be surprised if they were a third manufacturer. The pistons are IND Bras, so it looks like they're not original, and there is a possiblity that the 300 has sleeves in it, although I can't quite confirm that for sure.
So now I really have no idea how many miles are on the F150. Not that it matters since the truck will be completely new underneath when I'm done with her.
Shaun
  #24
Old 10-22-2012, 04:02 PM
Workin' Rig's Avatar
Workin' Rig Workin' Rig is offline
Stone Cold Bo Norris
Workin' Rig is a jewel in the roughWorkin' Rig is a jewel in the roughWorkin' Rig is a jewel in the rough
The 300 is a great engine, but its your truck. There not as fast as a 302/351 but pull better then a 302 does...and not to metion take alot more abuse.
1997 F250 HD 460/E4OD/4.10s
1977 F250 Camper Special
400/C6/3.07's all stock -FOR SALE 2800 obo
1978 F350 Dually -FOR SALE 1500 obo
400/T18/4.30's....not completly stock.
2008 Colorado 2wd
2.9/5sp/3.73's...the Daily driver.
"I am a FIRM believer that a properly tuned factory carb will perform just as well as EFI in 99% of all operating conditions".
  #25
Old 10-25-2012, 02:21 AM
BuzzGun79's Avatar
BuzzGun79 BuzzGun79 is offline
BuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond reputeBuzzGun79 has a reputation beyond repute
Well Shaun..you know what you have in the 300. it is easy for us to say build the 400 or what ever motor you want,ultimately its up to you.your doing a fine job so far.think about it compare the numbers do some homework on costs and runinng costs of a performance engine of your choice.stay within your means,you dont want something you wont be able to afford to drive once it is done.If it was me i would build the 400 and make one hell of a sleeper out of the truck retaining its current look.Ide rather have more & not need it,than to have less and wish it had more.
  #26
Old 11-12-2012, 06:40 PM
Ranger Lariat
Thanks BuzzGun!
I never concluded this thread, so here we go. The 300 was previously bored .030 over. Shoddy rebuild as the rod and main bores were out of round, which ended up eating the bearings. Not to mention all the rust buildup on the outer cylinder walls. I gave the 300 to a friend who eventually scrapped it.
I now have a 400, BB C6, New Process 208F all going into the truck. So I'm pretty much past the point of no return now.
The 300 right before it went to the scrapper:
My 400:
C6 4x4:
And the truck as it sits yesterday.
Shaun
  #27
Old 11-12-2012, 06:44 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
I'll bet you will be enjoying that 400!
Quote:
Quote:
Quote:
  #28
Old 11-12-2012, 06:45 PM
Ranger Lariat
Quote:
You better believe I will.
Shaun
  #29
Old 11-12-2012, 06:58 PM
DNFXDLI's Avatar
Admin
Are you going to go with the Aussie 2 barrel heads?
  #30
Old 11-12-2012, 07:20 PM
Ranger Lariat
Not on this 400. This build is focused solely on getting the truck going again. I miss driving it.
I can't say the same for my next 400. That will be getting a set of TMI pistons (If he's still kicking by then), and some other torque goodies.
Shaun
