Go Back   Ford Truck Fanatics > Special Interest > Motorcycle/ATV
  #31
Old 03-26-2016, 05:44 PM
fatherdoug's Avatar
Axle is in and problem solved. The only difference on the Rhino axle is that the hub nut is bigger than the old hub nut. The old hub nut was 1 1/8", and the new one was 1 3/16", but there was some slop on the 1 3/16". Could the new hub nut be (gasp!) metric? I can't verify that because I didn't have a metric socket that size. The 30 mm socket I had was too big. I got it tightened to 100 ft/lbs(186 nm) but it didn't feel right.
'78 F-150 Lariat
Quote:
Quote:
  #32
Old 03-26-2016, 07:15 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Could be metric Doug...my whole damn quad is...
Quote:
Quote:
Quote:
  #33
Old 03-26-2016, 07:17 PM
fatherdoug's Avatar
The first one I bought seems to be a mixture of metric/SAE.
'78 F-150 Lariat
  #34
Old 03-26-2016, 07:20 PM
DNFXDLI's Avatar
Admin
That is enough to make a guy want to stab himself in the eye with a fork...
  #35
Old 03-26-2016, 07:40 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
The only mixture of metric and sae I can handle is 1/2in-13mm
-Frank
Quote:
What's your view on sheep?
  #36
Old 03-26-2016, 07:45 PM
fatherdoug's Avatar
Quote:
That's what it was. How did you know?
'78 F-150 Lariat
  #37
Old 03-26-2016, 08:04 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
It gets better they are still mixed up to 2012 at least. I fixed a stripped drain plug for a friend, figured it was metric, much to my surprise the threads were 3/8-24.........
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #38
Old 03-26-2016, 08:06 PM
fatherdoug's Avatar
Ryan, do you know what size the Rhino axle hub nuts are? I am pretty sure they are metric, because the old hub nut would not thread onto the new axle shaft.
'78 F-150 Lariat
  #39
Old 03-26-2016, 10:14 PM
BIGRED911's Avatar
BIGRED911 BIGRED911 is offline
BIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant futureBIGRED911 has a brilliant future
9/16-14mm........
  #40
Old 03-26-2016, 10:19 PM
mrxlh's Avatar
Oilfield Trash
No clue on the thread size Doug, the new axle should have came with a nut and washer.
Lester
Stock
